As I understand, it is possible to get a rough estimation of an EI core transformer's power (VA) by finding the area in cm of the center leg (the part under the winding, not the full height). Square that figure to get the rough power. I'm not clear on what dimensions to use. Using the diagram, what do I use? A*B, C*B, or ??
#2 |
A x C
#3 |
I'm no expert on transformer design but I vaguely recall there are certain dimensional ratios that lend themselves to lower manufacturer production costs when stamping out the metal. You'd have to determine if it has that dimensional ratio before you could assume that multiplying only two dimensions would be appropriate as a change in the 3rd (whichever dimension remains uncalculated) would potentially affect the power rating.
#4 |
A good article on transformers and transformer winding including an Excel
calculator for core and copper losses. Practical Transformer Winding Another to answer your first question about power for core size. http://www.ludens.cl/Electron/Magnet.html Last edited by RJM1; 15th September 2011 at 05:45 AM. |
| power rail calculation | lt cdr data | Solid State | 5 | 5th December 2007 09:52 AM |
| Driver Power Calculation | GOWA | Multi-Way | 2 | 12th November 2007 09:40 AM |
| please help to clarify the coding | FYC | Pass Labs | 2 | 26th February 2007 12:50 PM |
| power calculation...correct? | lt cdr data | Solid State | 3 | 13th September 2006 11:45 AM |
| Page generated in 0.09181 seconds (74.86% PHP - 25.14% MySQL) with 10 queries |
