Go Back   Home > Forums > Amplifiers > Power Supplies
Old 12th September 2011, 02:23 PM   #1
merlin el mago's Avatar
Question Bulgin AC power switch
Hi have a couple of Bulgin AC power switch:
BULGIN|MP0045/1E2BL012|SWITCH, FLUSH LATCHING, BLUE ILLUM | Farnell Republika Slovenija
I measured the switch:
bicolour LED
Forward voltage Vf D1=3.80V D2=3.78V
Test current If D1=1.31mA D2 3.78V
D1 measured +- as marked in the switch
D2 measured +- inverted as marked in the switch
How have I to connect it?
Old 12th September 2011, 02:54 PM   #2
marce is offline marce  United Kingdom
Data sheet with contact details
http://bulgin.co.uk/PDFs/Cat83_Pages..._2010_p193.pdf
Old 12th September 2011, 03:56 PM   #3
Many thanks marce, still I don't know how connect the AC voltage? I can't understand NC1, NC2? only switch (have or not have continuity depending switch position) NO1 and C1 or NO2 and C2 so can switch on/off two devices, I read that some LEDs needs a series resistor, guys really I'm lost, please help will be welcome.
Old 12th September 2011, 04:09 PM   #4
I have these switches and I don't think you connect AC direct to it. It is a push button type not on/off type
I use this :The ε24 Power Switch Driver Circuit
Old 12th September 2011, 04:42 PM   #5
Thank you necplusultra, I believe my switches aren't the same like AMB uses.
Old 13th September 2011, 11:14 AM   #6
connect positive mains into c1 output from NO1
connect neutral mains into c2 output from NO2
the led !!!! cant remember whether the resistor etc is built in, sorry.
HV AC Selector Switch Rating spopepro Tubelab 1 27th February 2011 04:25 AM
Rotary AC power on/off switch for a dac? zeepreeme Parts 3 12th May 2010 03:15 PM
Capacitor Across Power Switch to Control Switch On Noise? DreadPirate Analog Line Level 17 1st March 2010 03:47 AM
fuse before AC switch? jarthel Parts 2 26th August 2006 02:22 PM
Page generated in 0.08516 seconds (73.43% PHP - 26.57% MySQL) with 11 queries
