Hello,
Roughly , What sort of efficiency could be achieved with a 1000W single switch flyback (Continuous mode) Vin = 150VDC-373VDC Transformer pri-sec isolation = 3500Vrms Vout = +-50V Switching frequency = 50KHz. |
#2 |
Hello,
Using flyback topology for that power level is a bad idea. We don't use flyback over about 200W because it's not magnetic efficient and cause high stress on primary switch. Prefer to use push-pull, more easy to design, smaller and much more efficient. With a good design,you could achieve easily over more than 90% efficency. Frex |
#3 |
Thanks, i see what you mean.
-So i will say the one transistor forward converter now. And to do that at 1KW instead. Just put a big enough heatsink on it and it will do the job? |
#4 |
Although forward converters can be used for more output power than flyback, 1kW in this mode is again a bad idea. You will have also hight stress in primary switch and the magnetic core will be big with high losses. It's nevertheless possible... You should really look for using push-pull converter type. You will have probably much more chance to get a functional smps... Regards. |
#5 |
thankyou, though i hear of flux-walking problems with push-pull smps?
#6 |
Use good ol' half bridge, or two transistor forward. Flux walking is not an issue there.
Though, there is a 7kW (at least that's what the service manual says) flyback in one of the big Lab Gruppen amps... can't recall off the top of my head which one it was tho. So it is possible... it's just not very efficient, unless you use big and expensive parts. On the other hand halfbridge will get you to 1kW for cheap. I'm applying the finishing touches on my adjustable split supply which goes from +/-20 to +/-60v, and in testing i have achieved 650W continuous output. I ran it for >1 hour no problem, cooling was a standard 80mm fan thermally controlled and it didn't even reach the max speed. Primary heatsink temperature was under 75C, it's the transformer and inductor that didn't let me continue further, i designed those for 600W max and they started getting hot. Efficiency was 85%, with the primary switches being bog standard bipolar 13009 devices, in TO-247. More specifically the Fairchild E13009L. Switching frequency 60kHz. I remember Eva pulled 4kW from a 13009 full bridge... so 1kW could be doable in halfbridge if you cool them well. Still, i would use MOSFETs or IGBTs instead.
"Audio grade" components simply means that they failed at a more critical job. |
#7 |
ok
but i prefer full bridge to half bridge...cheaper as less cost for film capacitors....also far less fet curretn...and over four times less dissipation in a fet compared to halfbridge. Half bridge difficult to layout nice cuzz of huge film caps in primary side |
#8 |
So why don't you use full bridge then? I agree, i was just too lazy to design something 100% from scratch - i actually used an old ATX power supply as my base, and built upon that.
#9 | |
For old-style push-pull inverters feeding a choke after the rectifier diodes, there is sometimes not enough volt-seconds available to reset the core. If you replace the inductor with a tapped inductor and feed the tap from the diodes and put a reverse-biased diode on the "new" end (the other end goes to the filter cap as before), the added diode gets slammed down a diode drop below ground but the tap remains at a high enough voltage to reset the core. I did this on a converter mounted on the Space Shuttle and used for the Hughes GEOS series of satellites in about 1976 and it eliminated a saturation problem immediately (before the era of current-mode converters). |
#10 |
amptramp,
Could you post a top level schematic of the supply you described in the second paragraph of your post? If not, can you further expalin the inductor and diode arrangemet? Thanks, Rick |
| self oscillating flyback smps | blackmamba | Power Supplies | 15 | 19th October 2011 06:51 AM |
| TNY266 flyback switcher | Khron | Power Supplies | 1 | 12th November 2010 04:40 PM |
| LM2575 for flyback? | lumanauw | Power Supplies | 6 | 9th October 2010 06:02 PM |
| 1000w out offline flyback | zerohead_ak47 | Power Supplies | 47 | 17th January 2009 11:32 AM |
| 110W Flyback | chimi | Power Supplies | 6 | 27th October 2008 11:38 AM |
| Page generated in 0.11913 seconds (82.09% PHP - 17.91% MySQL) with 10 queries |
