![]() I like to try different circuits. Using adapters as a power source. Which it has disadvantages be it can not turn on the negative power supply. However, this circuit can supply both positive and negative. This circuit is used IC number NE555 set up to stable multi vibrator.It produces a frequency rectangular patch of about 100 Hz.Out to pin 3 through C3 and C4. Before the rectifier power section. Both positive and negative DC 2 series.Positive power supply will work with the rectifier D1 and D2.When a positive signal to be via D2 to the output. And filtered from C5 to filter the pressure to smooth again...........Read more |
#2 |
What What Whaaat?
If your goal is to make a noisy 100mA supply then go ahead and use it. |
#3 |
Why are you taking bad circuits from another website and publicising them on here?
#4 |
These kind of circuits are great for learning though...
Tip, use high speed diodes (shottky) and increase the frequency to maximise efficiency. It would easily supply a few opamps and could be filtered using a "capacitance multiplier". Correct ground returns for the diodes and caps are essential.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#5 | |
But I wanted to know was published. If you do not know. |
#6 |
#7 |
When someone stops short and links to their website it is usually just an attempt to get website visitors for site ranking, advertising, etc.
Every post this member has made looks like an attempt to get people to visit wiparat . com |
#8 |
. . and that just links to eleccircuit.com - I'm not sure what is going on here. Why would someone want to publicise bad circuits? Let's hope we don't all find ourselves part of a botnet in a few weeks time!
#9 |
^ The attempt is (typically) to boost site ranking and draw in more visitors for the advertising displayed on the site, or profile tracking for later ad service. The site has two or three different trackers and a Google ad script.
| Negative volts and grounding in bench power supply | falcott | Parts | 11 | 29th April 2011 03:42 PM |
| Negative Effects of external power supply? | pjpoes | Solid State | 7 | 31st May 2007 11:37 AM |
| lm386 amp without negative power supply | triden | Chip Amps | 3 | 29th January 2006 11:02 AM |
| Power Supply Ground Confusion | Dwiel | Everything Else | 11 | 24th June 2005 07:46 PM |
| Low Power Negative Car Power Supply | Alcaid | Car Audio | 3 | 11th December 2003 03:32 PM |
| Page generated in 0.08835 seconds (86.67% PHP - 13.33% MySQL) with 10 queries |
