Go Back   Home > Forums > Amplifiers > Power Supplies
Old 5th September 2011, 10:33 PM   #1
Default hypex softstart for high power PSU
hello. here is a simple guide for modifying hypex softstart to handle a little more start current.
Cut out the current resistors R9 and R10.
get 2 CL-60 NTC resistors insted. solder them a bit over the PCB.
with some shrinktube over the legs. (make sure the NTC's can handle the current) the NTCresistors drops there resistanse when they get hot. and they get hot fast. so when the relè kicks inn, the resistense is low. now the softstart will handle a lot more current whitout welding the relè.
if this is not enougth. you can replace the 16A relè with a 30A relè.
you will however need to solder it with cabels when the relè has a bigger footprint then the 16A relè
mine now handels 1000VA transformer and 408.000uF cap bank.
thats with 16A relè.
soon to be: papa's Class A all the way
Meridan 557 Softstart and power caps TwangBar Solid State 6 15th November 2011 09:00 PM
Hypex Softstart alvinlim Class D 1 6th September 2011 12:59 AM
FS - Hypex SoftStart and Matched Quad Gold Lions EL34 lil' knight Swap Meet 4 21st February 2011 03:04 PM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 03:55 PM
LTSpice PSU simulation help - SoftStart modeling ninjanki Power Supplies 10 21st March 2005 04:04 PM
Page generated in 0.06195 seconds (65.13% PHP - 34.87% MySQL) with 11 queries
