Hi guys
I have a question about this LM7812 regulator Can I use several of this regulator(3 of them) with the same DC voltage? ( To power different circuits) |
#2 |
just another
Hi Badboy, Just want to clarify what you mean. Do you mean one input DC voltage (say 15V) feeding to three separate LM7812's which power different circuits?
If that's the case it should be fine provided the input has enough current capacity to power all three circuits. You may also need to pay some extra attention to grounding. Tony. |
#3 | |
thank your your reply yes, that's exactly what I meant Are you sure about this(you've tried this before) or you guess that's gonna be O.K?? and also could you give me some information about "the grounding" thing ( what do I have to do? doesn't they have the same ground that I should connect them to ground of DC supply??) |
#4 |
^ There are plenty of electronic devices using more than one regulator from the same supply rails. Yes it will be ok.
When the regulator outputs a voltage it is in reference to (0V) ground where that regulator is. Thus if powering a remotely located circuit where good regulation is important (in many circuits it isn't) you may want to use a ground return to the regulator or star ground, not a ground traces that passes by other regulators or subcircuits using significant current. |
#5 |
just another
Hi Badboy no I haven't tried it myself but I've certainly seen circuits that do have multiple reg's
What ! said with respect to sharing ground connection where significant currents may be present was what I was alluding to with the paying extra attention to grounding comment. Any benefit of muliple reg's could be undone if the grounding is not right. Tony. |
#6 |
Thank you all for your replies
really helped |
| FFT Noise Spectrum of the LM7812 three terminal fixed voltage regulator | rjm | Power Supplies | 7 | 24th December 2009 03:59 PM |
| LM7812 Test, PSRR 60dB at 100Hz ripple | lineup | Power Supplies | 7 | 6th November 2006 02:12 AM |
| lm7812-22v/2A in? | reever | Parts | 4 | 21st April 2005 12:20 PM |
| Lm7812/7912 | kinser | Chip Amps | 9 | 22nd November 2004 09:55 AM |
| regulator question | fezz | Parts | 12 | 16th April 2003 03:10 PM |
| Page generated in 0.08807 seconds (78.61% PHP - 21.39% MySQL) with 10 queries |
