Go Back   Home > Forums > Amplifiers > Power Supplies
Old 2nd September 2011, 10:18 PM   #1
Default Extra leads from transformer, et al.
Hey all. I'm a noob, and been quite the lurker at diy forums. So, pardon my lack of knowledge - and, yes, I've searched for answers to these q's, so please be gentle if I missed the threads.
If I'm recycling a transformer for a new project and have extra leads, can I tape them off - do I have to use *all* the leads that a transformer has?
When I tape them off, I assume that they should be individually taped...
Old 2nd September 2011, 11:41 PM   #2
nigelwright7557's Avatar
You dont have to use the whole transformer.
Tape off individually the unused wires.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 3rd September 2011, 11:04 AM   #3
Check which ends connect to which others. This identifies individual windings which can have intermediate tappings (i.e. more than 2 ends).
Each winding must be completely isolated from any other winding.
Ensure you have correctly identified the Primary Winding. The insulation/isolation standard for this winding is quite different from the others and is very important to the safety of the user.
Using less copper than is on the transformer core, reduces the VA rating of the transformer.
regards Andrew T.
Old 4th September 2011, 08:39 PM   #4
Just to make sure that I understand: there is one primary winding, which is the side that essentially "goes into the wall." The secondary windings are (at least in the transformers that I would be using at the moment) are electrically isolated and deliver a stepped down voltage than the primary windings.
There are four secondary outputs coming from the transformer, all of them center tapped. I plan on using three of them and the unloaded leads carry the lowest voltage, like 3.5v.
I plan on trying not to start fires...and using a leftover transformer from an RCA receiver to power a 6n11/LM3886 kit. I have questions about how to wire the transformer to it, but that's probably for a different thread.
Thanks for the advice on unused taps!
Teac AL-700P (plus extra amp module) dwk123 Swap Meet 4 15th January 2010 04:51 PM
Transformer leads 454Casull Parts 4 16th September 2009 03:07 PM
Identifying output transformer leads bereanbill Tubes / Valves 7 24th April 2009 02:27 AM
Steel Leads and Tinned Copper Leads impsick Parts 0 19th April 2009 10:01 AM
What about Al? MJL21193 Everything Else 6 28th October 2008 10:11 PM
Page generated in 0.07779 seconds (73.11% PHP - 26.89% MySQL) with 10 queries
