Go Back   Home > Forums > Amplifiers > Power Supplies
Old 2nd September 2011, 02:21 PM   #1
Default Suggest a board - 18vac to 12vdc
Hey Everyone,
I am building a CDA-254L kit from class D audio and have a spare 18vac output on the transformer that I wish to utilize to run a miniDSP and maybe a 12v case fan. So I need a board (very much preferably premade) that supplies nice clean power as my miniDSP will be my DAC.
Any suggestions? I have seen stuff on eBay but I have no idea of quality or what to even look for.
Thanks!
Mitch
Old 2nd September 2011, 03:15 PM   #2
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
well premade... look at DC-DC bricks or non brick version... just don't know how clean it will be, but you can always add some ultra low noise regulator after DC-DC
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 2nd September 2011, 04:42 PM   #3
I just need something that takes 18vac and turns it into 12vdc. If i have to make it myself i can try, but there is a lot of boards on eBay that do this supposbly, I just dont know how to decide wether they would be decent or not.
See for example: Class D Audio Heavy Duty DC Power Supply - Power Supplies - PRODUCTS but would also limit the voltage out to 12 vdc
Thanks for your reply btw
Old 2nd September 2011, 11:43 PM   #4
nigelwright7557's Avatar
I would just use a bridge rectifier, a dropper resistor and some smoothing.
You can work out the resistor value and wattage from the fans max dc current.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 3rd September 2011, 11:10 AM   #5
I would add on regulation.
Use an lm7815 or lm317 set to 12Vdc
the kit you need:
mains fuse holder
switch
transformer
bridge rectifier
smoothing capacitors
regulator
decoupling capacitors
solid core wiring in a variety of coloured insulation.
the knowledge
read ESP.
regards Andrew T.
18VAC transformer, what to do with it? asbus Power Supplies 6 2nd December 2009 02:38 AM
Wanted: Plitron 300VA 2 x 18VAC or similar ljfont Swap Meet 0 6th October 2009 06:17 PM
12vDC to 12vAC Cxrazy Parts 10 21st January 2008 01:11 PM
F1 at 15VAC instead of 18VAC? nightfire Pass Labs 2 16th October 2006 11:06 PM
Page generated in 0.07074 seconds (76.03% PHP - 23.97% MySQL) with 10 queries
