Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th August 2011, 08:18 AM   #1
Default Musical Fidelity P-140X PowerAmp without Transformer, need help!
hello guys,
this is the Schematic of the amp.
according to the sheet this amp has 2x70W output to 8Ohm speakers.
the amp is in good and orignal condition, only the trafo misses.
i think i should purchase a trafo with 2x42V secondary voltage and around 210VA((2x70W)x150%). or you guys have better ideas?
Old 6th October 2011, 06:48 AM   #2
Lenin21 is offline Lenin21  United Kingdom
Default You're on the right road...
Dual 42v secondaries should do it. I suspect that the original transformers on the P140, P170, P270, A370 had 45v secondaries (and consequently a rail voltage too high for those 63v rated caps that saw full rail voltage).
In terms of transformer size - I personally use the 'as big as possible' approach.
That said, if you want the original transformer, I have a pair of A100 transformers - which I suspect are the same item used in the P140. (More knowledgeable members will appear shortly to confirm, or otherwise).
Musical Fidelity Typhoon transformer was burnt impuls Solid State 0 24th March 2010 11:14 PM
musical fidelity b200 transformer sakis Solid State 4 4th July 2009 09:04 PM
Musical Fidelity B1 amp transformer problem. nairod156 Parts 2 26th May 2008 08:00 PM
Musical Fidelity E60 Transformer??? delory Digital Source 0 25th July 2005 03:22 PM
Musical Fidelity- Do you know it well? SugarMedia Solid State 2 26th February 2005 01:11 AM
Page generated in 0.06655 seconds (68.65% PHP - 31.35% MySQL) with 10 queries
