Connexelectronic
According to the datasheet, it has a 10R and a 100 nF cap in parallel (I hope) between the output ground and chassis/earth, through the electrically-connected outer mounting holes; e.g. the plating on the mounting holes need to be shorted to the case. Also, according to Earthing (Grounding) Your Hi-Fi - Tricks and Techniques, there should be a high-current bridge rectifier along with the resistor and cap for fault currents. Does the bridge rectifier need to be added, or is what is on the PS board sufficient?
Building a 2.1 system out of a 3/4"x4'x8' sheet |
| Connex Electronics TA2022Amp | eelind | Class D | 2 | 22nd February 2011 01:26 PM |
| FS: Connexelectronic TA3020 v3b, A1000SMPS, BIPS - for parts/repair! | mx2 | Swap Meet | 9 | 21st January 2011 10:09 AM |
| connex TA3020 v3c | lbstyling | Class D | 5 | 22nd August 2010 10:03 PM |
| 15000ufx6 63v Connex PS | wushuliu | Swap Meet | 1 | 17th June 2010 02:59 AM |
| Building Connex NXP amp | Kjeldsen | Class D | 1 | 8th April 2010 08:04 AM |
| Page generated in 0.07116 seconds (66.62% PHP - 33.38% MySQL) with 10 queries |
