I have two Hifimediy T2 amps and each can take 22V AC. Will I be able to use 1 400VA transformer to power both at the same time? Or do I need to have an individual 200VA trafo for each? The single 400VA is cheaper than two trafos and also smaller footprint.
#2 |
One will work, I am using amps with one transformer supplying two channels right now. As long as it has enough current capacity, it's all good.
Mike |
#3 | |
Look outside at the power pole. All the appliances in your house (and probably your neighbors') are running off that one transformer. Current capacity is what matters, like Mike says. |
| Mcintosh amps transformer rewinding, help needed please! | cchean | Tubes / Valves | 41 | 22nd October 2011 11:36 AM |
| Best transformer size for Class D amps? (non-switch mode PS) | Dr.H | Class D | 1 | 15th April 2011 07:17 PM |
| Transformer Amps | Definity | Solid State | 13 | 5th September 2010 09:18 AM |
| What Solid State Amps with Output Transformer do you know of? | Onvinyl | Solid State | 27 | 27th April 2010 10:41 PM |
| Transformer for Tube Amps? | samsagaz | Tubes / Valves | 2 | 3rd February 2009 06:58 PM |
| Page generated in 0.07090 seconds (68.46% PHP - 31.54% MySQL) with 10 queries |
