Hello,
I have come across quite a few 10nF EMI suppressing Metalized Paper 1000VDC capacitors. I am in need of a few 3n3 capacitors for a snubber circuit in my power supply. Three of these 10nF caps in series will give me roughly 3n3. What would be the benefits & drawbacks for using these in my snubber circuit? Thanks. |
#2 |
Would you need equalising resistors?
#3 |
Yes, .1 Ohm, I've got that taken care of.
#4 |
I was thinking of something more like 100k-1M, to ensure that the applied voltage is shared evenly across the caps. Not necessary if your voltage can be handled by one cap.
#5 |
snubbers are there for high frequency, series connection increases inductance making the series caps less effective
#6 |
You wouldn't think that a few small caps would impede audio frequencies.
#7 |
maybe you're talking about something else but in PS "snubber" has a very specific use - to cut RF/EMI generated by reverse recovery rectifier diode turn off spike
the problem is not audio frequencies, it the potential conduction/radiation of RF frequencies from the rectifier's fast current edge to sensitive semiconductor inputs where it can be "detected"/demodulated in the amplifying device nonlinearity |
#8 |
I See.
I'm working on the audiosector LM4780 Kit and there is an optional selection of a 3n3 w/ .1R in parallel to a 10,000uF for each rail. These components are referred to as snubber components. Would that be incorrect? |
#9 |
I don't know the Audiosector layout but to be effective the snubber networks should be right at the diode terminals with minimal loop area, short leads, extended foil construction if using film caps - try a search of diyAudio: username "Eva" and "snubber" will get you some real measurements
you should be able to use much smaller (physical size == less inductance) caps on the secondary = 100 V rating shoud be quite adequate for 22 VAC sec Last edited by jcx; 21st August 2011 at 10:58 PM. |
#10 |
Einric,
The capacitor pictured in your first post is a special type designed to safely take all the abuse of being placed across the AC power line.
Kevin |
| Emi 92390 | T11 | Full Range | 16 | 15th February 2007 10:57 PM |
| EMI shielding... how? | taj | Parts | 10 | 16th March 2006 02:23 AM |
| NOISE - RFI and EMI | jackinnj | Everything Else | 9 | 26th February 2005 01:01 PM |
| Anybody can identify that EMI filter? | Peter Daniel | Digital Source | 12 | 3rd February 2004 09:15 AM |
| An idea for suppressing the turn-on "bump" | Bricolo | Pass Labs | 11 | 4th May 2003 06:21 PM |
| Page generated in 0.09704 seconds (78.43% PHP - 21.57% MySQL) with 11 queries |
