Go Back   Home > Forums > Amplifiers > Power Supplies
Old 19th August 2011, 05:55 PM   #1
Boscoe is offline Boscoe  United Kingdom
Default How do power leads make a difference to sound?
I've been looking through of HiFi forums recently only to discover the rediculas discussions on offer. Like how different power leads make a difference to the sound of your system? I mean how does it? There is no electronic theory explanation is there?
I love of this diy community is immune to this pointless and stupid topics like these!
I thought about it once, but then thought again.
Old 19th August 2011, 06:15 PM   #2
DF96 is offline DF96  England
Possible explanations:
1. they don't make any difference.
2. they affect the amount of RF pickup, which can affect unfiltered equipment.
3. they have a marginal effect on charging pulse shape and hence harmonic generation.
I will leave the 'true believers' to offer their alternative explanations. Given the miles of cable from the power station, and hundreds of metres from the local supply transformer, and tens of metres within the house, it is astonishingly unlikely that any significant change can be effected by the last two metres!
Old 19th August 2011, 06:27 PM   #3
I'm sure the very little changed by the last two meters won't compare to the things connected to it and where they are in the room and such.
Old 19th August 2011, 06:46 PM   #4
stormsonic's Avatar
4. all cables have real components like resistance, inductance and capacitance. Therefore cable will act as filter (or as pickup) and last two metres of cable are much more important than hundreds of meters before.
Differences are audible and expensive cables are not always better.
But no power cord can transform your POC amp to the SOTA amp
Old 19th August 2011, 07:00 PM   #5
digits's Avatar
They always sound better to the guy that paid for it all... or he'd go nuts.
Old 19th August 2011, 07:02 PM   #6
Why? This could just about be true if the main problem was high microwave pickup which was attenuated quickly by lossy PVC insulation. Then the last 0.5m might matter. To improve things we could choose an even worse dielectric.
Old 19th August 2011, 07:04 PM   #7
If you care to measure 1/3 to 1/2 of the total AC power line resistance is in the power cord and connectors!
But it is mostly the RF filtering that can be done in a cord without increasing power loss as an inductor would do that is the biggest asset.
Old 19th August 2011, 07:10 PM   #8
bbggg is offline bbggg  United States
But far less important than the power supply that follows.
Old 19th August 2011, 07:11 PM   #9
But how does that compare with the transformer resistance? In most cases probably negligible. However, a high mains lead resistance will help reduce current rise times and so reduce mains harmonic generation. Use the thinnest lead which will not melt with the current! (OK, I'm not being entirely serious - we are talking about a very marginal effect).
Old 19th August 2011, 07:20 PM   #10
The transformer resistance is inside the magnetic loop and has less of an effect than circuit theory would show.
Do bindingposts make a difference to the sound? soundengine355 Multi-Way 15 24th August 2009 02:37 AM
Will this upgrade make a difference? brox Subwoofers 14 9th April 2007 07:12 PM
Why does a TT's power supply make a difference? jugi63 Analogue Source 0 27th October 2006 06:12 PM
Page generated in 0.10968 seconds (79.50% PHP - 20.50% MySQL) with 11 queries
