Go Back   Home > Forums > Amplifiers > Power Supplies
Old 15th August 2011, 11:44 AM   #1
Default DNM T-network cap in conventional power supply??
Hello!
How I wire this cap (4 pole) in conventional power supply that supposed to work with 2 pole capacitor?
DNM Products - T-Network Capacitors, full details
Thanks!
Old 15th August 2011, 12:03 PM   #2
You can either modify the power supply to have an in- and output for the capacitor, or you can combine the positive in with the positive out and the negative in with the negative out, but I do believe you lose much of the advantages of the T-network caps.
Personally, I'd modify the PSU, should be relatively straightforward.
DNM Power Amp Circuit Diagrams Wanted mozfet Solid State 3 29th August 2009 09:10 PM
Inrush current sources in a conventional supply rtarbell Parts 4 20th July 2008 08:08 AM
power supply (cap input) jarthel Tubes / Valves 2 15th June 2007 08:51 AM
DNM T-Network Caps pinkmouse Parts 1 14th November 2004 03:41 PM
DNM Power Amp Diagrams mozfet Solid State 0 14th January 2003 09:03 AM
Page generated in 0.05896 seconds (73.39% PHP - 26.61% MySQL) with 10 queries
