Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th August 2011, 04:52 PM   #1
Thumbs down 12V(fixed) with 3 Amp current
Hi
I have a circuit that run with 12V(fixed) and need about 3 amp current
can anybody help me how can I invert 18V DC to 12V DC(fixed) with around 3 amp current
tank you
Old 13th August 2011, 05:01 PM   #2
Minion is offline Minion  Canada
Just use a 12v Regulator with a Pass transistor to get the 3A of current .... Your 18v DC is going to have to be capable of 3A .....
The LM317 has schematics in its Datasheets that show how to do this ....
http://www.national.com/ds/LM/LM117.pdf
Cheers
Old 13th August 2011, 05:10 PM   #3
Thank you so much Minion
did you do it yourself?( using any of these circuits or have the same need)
Old 13th August 2011, 05:12 PM   #4
Here-http://www.national.com/profile/snip.cgi/openDS=LM350
Old 13th August 2011, 05:17 PM   #5
I used a very simular curcuit to build a 5a 24vDC PSU for a small Class A amp and it worked fine , just remember to heatsink the Pass Transistor and regulator ......
Old 13th August 2011, 05:31 PM   #6
thank you "Michael bean" and "Minion" for your advices
Old 13th August 2011, 05:54 PM   #7
! is offline !  United States
I don't know what your skill level is, but I would find another way, 18W of heat for a mere 12V application is a lot in added size, weight, heatsink cost as well as chassis cooling considerations.
You seem to have left out the most important part, what the PSU is powering. Voltage and current is only a means towards an end, everything else really matters more including budget, skill level, space, weight, efficiency, powered device, permissible noise, etc.
Old 13th August 2011, 06:54 PM   #8
Hi !
I'm neither beginner nor pro
could you tell me what idea do you have for my goal???
Old 13th August 2011, 07:08 PM   #9
^ Buy a ready made step down switching power supply module. I have no idea where you should look since I'm in the US and you are listed as being in England but bear the flag of Malaysia. Such a module with roughly 18V input to 12V output should be popular for DIY solar (panel) projects as a regulator between the solar panel(s) and batteries to charge them, if you can't find something with those spec at an electronics surplus website.
Of course you could try building your own, go to your perferred electronics supply house or electronic chip manufacturer's website (for example National Semiconductor) and browse to the appropriate chip product that meets the functional goals then the respective datasheet will give an example to follow.
Old 13th August 2011, 07:12 PM   #10
thanks a lot "!"
High Current Power Supply 12v, with zener on base jacquesl Power Supplies 13 26th August 2007 05:30 PM
12V DC/DC for amplifier. Current limiting? Pierre Power Supplies 22 1st May 2007 11:46 AM
How much trickle current can fixed bias cathode batteries stand? zobsky Tubes / Valves 5 21st October 2006 03:51 PM
12v regulated toroidal charger high current bowdown Power Supplies 7 28th September 2005 04:22 AM
Page generated in 0.08935 seconds (78.92% PHP - 21.08% MySQL) with 10 queries
