I am building a small DAC using UDA1352TS. It calls for a 3v supply. I am using a 15v supply with a LM317 (TO-252) regulator with 220 and 330 ohm resistors. Also a 10uF input bypass cap. I'm wondering about heat dissipation of the LM317. Is there going to be too much heat for the LM317?
Professional Newbie. |
#2 |
How much current would it draw? Look at the datasheet, it has pretty clear graphs that shows you what you can get away with, with appropriate heatsinking.
My advice would be though to get a small PCB mount transformer, say 5 or 6VAC and regulate that down for greater efficiency and less heat. |
#3 |
The DAC chip pulls around 13mA if you add up the analog and digital supply currents.
That gives you about 150 mW of heat for the regulator, at 12V across the regulator. A TO-252 will get a little warm, but will be fine. Tja = 103C/W, so expect a 16C rise in temperature for the regulator. |
#4 |
Thanks, that's what I had decided. I hooked my prototype up to a 15v supply. It ran a little warm but didn't really get hot. Thanks again to both.
#5 |
I am not a digital Member and don't know how the DACs work, but quoting 13mA for the combined Digital and Analogue current draw does not seem right.
regards Andrew T. |
#6 | |
http://www.nxp.com/documents/data_sheet/UDA1352TS.pdf Something like 9.3mA for the digital section and 3.6mA for the analog section. Last edited by discrete; 10th August 2011 at 03:01 PM. |
#7 |
The 3mA of maximum analogue output and the Pmax~38mW seem to confirm
your original post.
regards Andrew T. |
| Need suggestion for 6.3V-0-6.3V | xecluded | Tubes / Valves | 25 | 25th June 2011 02:56 AM |
| Circuit Sanity Check: +15V, -15V, +9V Power Supply | miallen | Power Supplies | 4 | 18th July 2009 07:18 PM |
| +/-15V power to a TI PGA2310. 15V regulators sufficient or do I need adjustable?? | nick_g_evans | Parts | 2 | 16th July 2008 11:50 AM |
| How to get +15v and -15v from 12vdc | mbcouple | Everything Else | 15 | 25th June 2005 05:25 PM |
| Need some help here,please - 3V only amp! | Petman | Tubes / Valves | 5 | 15th May 2002 11:27 AM |
| Page generated in 0.07971 seconds (84.96% PHP - 15.04% MySQL) with 10 queries |
