Audio Junkie
I am trying to gain some understanding of what the important facts are regarding power supplies and digital audio and let me explain what I mean by that a bit farther.
I am building a DAC using dual PCM1794A DAC chips, a CS8416 Mux and a USB board. So looking at the power supply requirements for the PCM1794A chips: http://www.ti.com/lit/gpn/pcm1794a We find that the 1794A has FOUR power supply pins. Vcc1 - Analog 5V power supply Vcc2L - Analog 5V (L-Chan DACFF) Vcc2R - Analog 5V (R-Chan DACFF) Vdd - Digital 3.3V supply So I would think obviously we would want to separate the digital and analog supplies. not only because of the different voltages, but to keep digital noise out of the analog supply lines. Now is there any reason why the three analog 5 volt supply lines should be separate? even a minute amount of channel separation or lowered noise floor etc? and if there is a reason too, can we use one transformer winding, bridge, cap bank and then just use 3 voltage regulators? or do we need separate transformer windings for each? I would imagine the 3.3V Digital line would want its own winding? or can that too be run off the same winding as the 5V analog lines? lets discuss. Zc
It's not about what you can BUY...It's about what you can BUILD! |
#2 |
I would use seperate regulators but a common winding.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
Audio Junkie
for the analog and digital too?
#4 |
Sometimes a square peg fits a round hole just fine
definitely use the same winding for all the analogue supplies, separate regs, but they should have a common ground referrence, i would also run the XO from the same winding, the dac internal analogue reference, analogue output stage and the oscillator should all connect to exactly the save ground potential, even star grounding from different tx could produce enough variance to effect performance
| Class d audio ti 600's and power supplies for sale | nhuwar | Swap Meet | 0 | 16th January 2011 10:09 PM |
| WTS 8 GB150D amplifier modules and 4 GB150S2 power supplies from ska-audio.com | Didush | Swap Meet | 0 | 26th August 2009 11:28 PM |
| 8 GB150D amplifier modules and 4 GB150S2 power supplies from ska-audio.com | Didush | Swap Meet | 0 | 1st August 2009 09:06 PM |
| Selling 8 GB150D amplifier modules and 4 GB150S2 power supplies from ska-audio.com | Didush | Swap Meet | 0 | 22nd July 2009 01:48 AM |
| MODDING commercial RECEIVER for seperate digital outputs !! | JinMTVT | Digital Line Level | 3 | 1st September 2008 02:44 AM |
| Page generated in 0.08755 seconds (78.71% PHP - 21.29% MySQL) with 10 queries |
