Location: Lawrence, a nice little college town in Kansas
I'm designing my first power supply for a class A/B amp. Searching for filter caps, I found they are often described by the manufacturer as "audio grade", "computer grade", "general purpose" or other descriptions. For a given capacitance and voltage value, the electrolytics described as "audio grade" were among the least expensive, and often the ESR and leak were not listed in the data sheet.
So, to finally get to my questions:
Any advice from more experienced builders is greatly appreciated. Last edited by ByronInLawrence; 3rd August 2011 at 02:06 PM. Reason: details details |
#2 |
The design looks like overkill so the capacitors will be not be stressed. Even 80V pcb mount types should do. SMPS rated devices usually have low ESL and ESR. 105C rated devices last longer.
Use the equivalent circuit of the components in the simulation to simulate what effect of ESL leakage and ESR are. Google and wikipedia will help explain both transformer and capacitor equivalent circuits. Audio is not a demanding application so that is why audio capacitors should be cheaper. Forget any marketing diatribe, that is what happens when anything enters the consumer market |
#3 |
There are radical difference in the expected life of caps. Depends on whether they use the rubber sealant, or the expensive stuff. I buy the one with the 8000 hour life rating at 105 deg C if I can get it, 2000 hr if I can't. A lot of 1000 hour caps are still stocked for repair people whose customers don't care. Usually ESR doesn't matter in these life ratings, but 10000 uf comes in a much cheaper "tall' version with *****y ESR. Replacing some 10000 uf @ 100V recently, I bought twice as many 4700 uf caps at 5/4 the ESR and 1/3 the price each. Then I doubled them up on a little CB I made with lexan, 18 ga wire, and steel angle brackets. Glued the caps down with silicon seal, but wall board adhesive will work as well. Weren't a lot of choices in 10000 uf caps, looking for in stock items only. These were radial, soldered the wire to the leads through the new CB. The stock spacing (10 mm) and the old "4 peg" spacing, did not match.
The only thing I've noticed about "audio" caps is that mcmelectronics charges about 4 times as much for them as the series I find in AB motor drives- the ones that run 8 years in an industrial oven motor compartment.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500 Last edited by indianajo; 5th August 2011 at 06:04 PM. |
#4 |
The LED won't last long
By far the biggest contributer to noise/distortion/hum etc etc etc is your physical layout of all the tracks on the PCB for the main amplifier and what connects where on those tracks. PSU's are important but just throwing lots of capacitance isn't the answer IMO. A good amp rejects rubbish on the rails anyway. Also the more capacitance on the rails and the shorter the time the bridge conducts for... but the same energy as lower capacitance rails still has to be put back for a given load. That means the peak currents are correspondingly higher, copper losses become significant and the transformer may well technically be pushed beyond its ratings.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#5 | |||
Thanks everyone! I was worried no one would respond to me post. Then all of a sudden . . .
Transformer is rated at 300VA, and I'll be using two. It's a dual-mono design. I included the data sheet, but I don't know how to interpret all those numbers. Do you think they might be stressed? Of course, it's kind of late now. Included is the data sheet for the filter cap I decided on. It's new at Mouser. Thanks again for the advice! |
#6 | |
Use any LED, calculate R for 2-5 mA. It will last forever. On a side note, the 500 ohm discharge Rs you have are somewhat counter productive (120 mA, 7W at 60V). I usually do not use them, but consider 10k minimum if you must. Last edited by discrete; 6th August 2011 at 01:31 AM. |
#7 | |
Yeah, 500R is way too low. I'll up the bleeders to ~2kR. Thanks for the help! |
#8 | |
An intermediate value between 200nF and 10,000uFs will be helpful in suppressing LC resonances between the caps---I don't have the link handy but there's a great thread in this forum (or maybe solid state) with quite a bit of data on the issues. A good rule of thumb for avoiding the problem is two order of magnitude steps; it varies from design to design and board to board but I often end up with 100nF 0603 X7R || 4.7uF 1206 X7R || 220uF 5mm aluminum || 22,000uF 25mm aluminum as a starting point. At higher voltages you'll need a 'lytic for the low uF range and a larger package on the MLCCs.
#9 |
Do yourself a favor and use Epcos LL caps.
#10 |
Thanks twest820. I understand your first suggestion, and I think I'll add a pair of 5000uF electrolytics.
I didn't follow the second part. I'm relatively new to this with no formal training in electronics. I don't know what you mean by "KWs" and "VRs". I also don't know what the amplifier's PSRR (Power Supply Ripple Resistance?) is, or how to figure out how good it is. I'm relying on the reputation of the designer. It's the DX Blame MKIII by Carlos Mergulhao. HornTube, I assume these are the "long life" caps. How are these better than the myriad of other capacitors available? |
| Do I Really Need Filter Caps? | DreadPirate | Solid State | 6 | 21st August 2009 06:47 AM |
| Filter caps | DeadSpeaker | Solid State | 5 | 11th June 2008 04:17 PM |
| B+ filter caps | nhuwar | Tubes / Valves | 12 | 26th January 2007 09:33 AM |
| Just one big filter cap or more smaller filter caps ... | beppe61 | Power Supplies | 2 | 18th July 2006 05:46 PM |
| The size those filter caps should be, or not | alitaido | Power Supplies | 0 | 6th July 2006 07:48 PM |
| Page generated in 0.13866 seconds (84.00% PHP - 16.00% MySQL) with 11 queries |
