Go Back   Home > Forums > Amplifiers > Power Supplies
Old 1st August 2011, 04:26 AM   #1
troyo is offline troyo  Guyana
Default transformer rewinding
hi want wind a 70-0-70 5000w i have an old 5000w stabilizer transfromer with a core area of 80 cm square .what size of wire(mm) would u recomend for this and the turns to be used
Old 1st August 2011, 06:29 AM   #2
i'll plug the numbers into my spreadsheet later (i'm at work) but i doubt that is a 5 kw transformer.
Its probably good for around 2 kw, because most voltage stabilizers are configured like an auto transformer with a capacitor and a magnetic shunt.
what are the dimensions? do you intend to rewind the primary as well? if not what is it wound with and how much window area does it take up?
Old 1st August 2011, 08:32 AM   #3
core area: 80cm square = ?
do you mean 80cm by 80cm?
or
do you mean 80square cm? i.e.~10cm by ~8cm
If the latter 80sqcm then that is ~ 12sqin.
A disputed formula for arriving at VA rating is
VA ~= 30 * [sqin]^2
For your 80sqcm VA ~= 30* 12.4*12.4 ~4.7kVA
Is the magnetic circuit completely closed, i.e. no deliberate air gap?
regards Andrew T.
Old 1st August 2011, 12:49 PM   #4
my reply was in haste.
80 square cm of core gets you 42 turns needed for the primary at 1.3T.
this means you can fit 9 parallel strands of 10 awg wire assuming that's a loss-less cut.
for the secondary 8 parallel strands should fit. 9x46 turns (window area of 125mm by 42mm)
If the iron consumes 5 watts per kilogram it will dissipate 162 watts.
for the copper to match that you have to pull 12KW from the transformer.
In real life thermal limits will be reached at probably half this because you won't be able to fit 9 parallel primary coils of 10 awg unless you use an equivalent copper strip for the primary and secondary. the excition levels may have to be cut below 1.3T if 160 watts no load is too high. but 1.2T is probably good and that will cut the optimum efficiency point down to around 9.5kw.
if you cut it down to 1.2T then you need 46 turns for the primary and that means you can only fit 8 strands of 10 awg and 7 times 54 turns for the secondary.
keep in mind those are theoretical figures that are difficult to achieve in real life, but can be exceeded by using copper strip.
Old 1st August 2011, 02:07 PM   #5
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
what is you line frequency, mains voltage, secondary voltage?
Help with rewinding a transformer santonel Power Supplies 14 21st October 2010 01:12 AM
Transformer rewinding material elseif Parts 2 5th September 2008 12:30 AM
Rewinding Power transformer ThSpeakerDude88 Tubes / Valves 11 27th August 2007 02:07 AM
Bad transformer rewinding ostie01 Solid State 16 18th May 2006 09:08 AM
Transformer Rewinding JhonDoe Parts 3 1st March 2005 12:15 PM
Page generated in 0.08460 seconds (76.77% PHP - 23.23% MySQL) with 11 queries
