Go Back   Home > Forums > Amplifiers > Power Supplies
Old 28th July 2011, 07:09 PM   #1
Default What transformer do I need?
I was given a broken KEF PSW 2150. When I plugged it in after 30 seconds or so a relay inside of it started clicking on and off constantly. I dug around in it and found the transformer is outputting 39vac yellow to black mid 70s yellow to yellow. I think it should be 50vac per yellow but I'm not sure. Could someone tell me if I am right and what would be the best replacement?
Old 28th July 2011, 09:17 PM   #2
What is the voltage reading of the 2 large power supply capacitors.
A transformer of 2x39Vac would give you plus and minus 53Vdc. Voltage of the caps is then most likely 63V. A 2x50Vac transformer would give you plus and minus 71Vdc. The caps should then be rated for 80V
Old 28th July 2011, 09:48 PM   #3
kevinkr's Avatar
Likely there is something else wrong with this unit that is loading down the power supply. Relay cycling is often an indication of a fault somewhere like a blown output device or power supply problem..(Amongst many other possibilities too numerous for me to think about.. )
www.kta-hifi.net
Old 29th July 2011, 12:45 PM   #4
Thanks Jeronimo and Kevin, the capacitors are 63V. As you can probably tell by now I am new to repairing electronics. I have been reading a lot of articles. People are saying the small cap at C52 next to the big cap has been failing and causing this issue. I'm going to test that. I'll let you know what I find.
These are the caps.
I have read a lot of post where people say this cap has been failing.
This is the transformer I thought might be bad.
Old 29th July 2011, 11:42 PM   #5
Failure of a transformer is very rare and usually accompanied by smoke or blown fuses. The transformer sounds like it is 37.5V 0 37.5V which will give +/- 50V dc supply rails. As mentioned you should measure the voltage on the filter capacitors which should be close to 50V
Where you buy iron transformer core for DIY audio transformer tarsik Tubes / Valves 10 27th December 2011 08:15 PM
Dynaco 440 Transformer Cathode/Screen Taps 6P1P 6AQ5 UL transformer TheGimp Tubes / Valves 14 30th October 2011 12:20 AM
Using a large 60hz toroid transformer as an SMPS transformer EWorkshop1708 Power Supplies 20 22nd June 2011 08:05 PM
TV Fly-Back Transformer as and Audio Transformer Anyone :) AB5NI Everything Else 7 10th June 2011 11:22 PM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Page generated in 0.07848 seconds (72.59% PHP - 27.41% MySQL) with 10 queries
