Go Back   Home > Forums > Amplifiers > Power Supplies
Old 26th July 2011, 06:14 PM   #1
Default 2.5V to power LED
Hi gyus,
I have a PSU (for pre amp) that have +/- 24V and +/- 12V. I need to get a power for two LEDs (stand by and power indicators). What would be the easiest way to do it?
Thank you!
Cheers, Marin
Old 26th July 2011, 06:19 PM   #2
Mooly's Avatar
Led and resistor... doesn't come any easier. The series resistor is calculated using ohms law.
e.g. 12 volt supply. LED current needed say 5milliamps. Volt drop across LED say 2 v nominal. That varies with colour of LED but with highish supplies it's effect on the calculation is negligable in practive.
So we (12-2)/0.005 which is 2000 ohms. So 2K2 would be nearest...
A simulation free zone. Design it, build it, test it.
Old 26th July 2011, 06:59 PM   #3
I was thinking along that (ohms law) line but wasn't quite sure how to apply it B-(
Thank you Mooly!
Cheers, Marin
Old 26th July 2011, 07:04 PM   #4
Mooly's Avatar
Your welcome...
Also some LED's are super efficient and may be bright enough at even lower currents. It's trial and error really to get the brightness that looks acceptable to you.
Old 26th July 2011, 07:17 PM   #5
Actually, I will feed several different LEDs, the yellowish one as a stand by, green as power and 6 blue (input selection indicators). Each of them needs a slightly different voltage so, as you said, it is a "try until you happy" process.
Since now I am on good track it would be much easier to play.
Cheers, Marin
Old 27th July 2011, 05:03 AM   #6
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
just note, that leds are more happy with constnt current source then constant voltage source
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 27th July 2011, 03:47 PM   #7
Hvala Luka B-)
So what is your suggestion, should I use resistors only or something more sofisticated?
Cheers, Marin
Old 27th July 2011, 04:08 PM   #8
Resistors are fine given that the supply voltage dominates what the current will be.
Old 27th July 2011, 05:30 PM   #9
luka's Avatar
with constant voltage supply, resistor is ok
if a bit more advance, transistor and one or two more components will be needed
if even more, led driver would be the best
I FEEL SLOVENIA
Old 27th July 2011, 07:45 PM   #10
No need for such elaboration at all. LEDs have very low dynamic resistance and therefore also low noise (Zd well below 50ohms at 1mA, depending slightly on colour and operating current) so follow Mooly's example - pick an operating current and calculate and appropriate resistor.
Even easier - 10K works for almost anything. If it's not bright enough, tack another 10k in parallel. Repeat until happy.
Power One 5v 3A linear power supply SilverStrings Swap Meet 0 23rd September 2010 06:06 AM
5V dc power supply FOXYE Power Supplies 3 2nd May 2009 07:29 AM
1.5V power supply for mp3 player leo14m3 Power Supplies 2 16th October 2005 01:22 PM
5v DC Quiet power supply bjackson Power Supplies 4 6th September 2005 03:25 PM
Can you make 0-5V DC out of 2.5-0-2.5V AC Ralph Tubes / Valves 17 23rd September 2003 03:20 PM
Page generated in 0.09315 seconds (74.58% PHP - 25.42% MySQL) with 10 queries
