#21 | |
If you use an EI transformer consider getting one with a copper shorting strap around the outside to reduce stray fields and keep it away from any unshielded signal tubes. electrons in vacuum are very sensitive to magnetic fields. |
#22 | |
Antek - AS-4T400 |
#23 | |
meant to type 12a[t,u]7
dont think anyone mentioned it, but aside from electrical/magnetic efficiency you obtain from toroid, they do not vibrate like EI's sometimes can (and thus make a audible hum) Last edited by ryuji; 6th August 2011 at 10:52 PM. |
#24 |
First... remember your rectifier tubes will have a voltage drop.
Second, as a good rule-of-thumb, always over specify by at least 20%... it comes in handy at times. Third, so long as you have faraday shields (copper straps around windings), and outer metal cans, E-I wound transformers are not inferior to toroidal. And cost a bunch less, generally. Fourth, here would be my specs for the transformer: Primary - split, for 120/240 operation. Secondary 1: 5 VAC, 3.5 amp. Secondary 2: 6.3 VAC, 4 amp (you might want more sections!) Secondary 3: 300-0-300 VAC, center tap, 500 ma continuous duty. Now that last part is tricky: each of the halves only is delivering current during half of the 50/60Hz power sine-wave. So, the wire used in the winding only needs to take "250 ma" average. This kind of makes sense from a different perspective: if P = V·A = 300·0.5 = 150 VA, then 150 VA = 600·0.25 too... Consider the Hammond 372HXP as an almost-perfect fit. See... Hammond Mfg. - Universal Primary - "Classic" Potted Power Transformers for tables regarding these. There is no reason to over-specify. Don't worry about slightly over-tapping the 5 volt line... while there will be additional heating on that secondary, it will be offset by much lower heating in the 6.3 secondary. Everything will come into thermal equilibrium after a 10 minutes of power-up or so... GoatGuy |
#25 |
They're not inferior anyway- they can have slightly greater radiated field, but the efficient coupling of high frequencies of a toroid is a disadvantage in power transformers. On balance, an EI is a better choice. Toroid power transformers are compact and (these days) cheap, but are at the bottom of the desirability ladder for performance.
If there's a sucker born every minute, where do the rest of them come from? |
#26 |
SY: I respect your opinion re: the markedly increased frequency response of wound toroids over E-I (or C, or F, or R, or E:E, or C:T) stamped-core designs. And I agree with it/you. With now some 40 years experience [yep, {old} am I], all I can say is: its all about the regulation in the end.
Taking the time (and intellectual interest) in competently designing power supplies that have excellent isolation between the rectification sections, pre-filtering, stage-1 regulation, secondary filtering, stage-2 regulation, and active-circuit compensation should, when done right, become entirely transformer agnostic. In testing, I've actually show this to be the case. I've also intentionally "messed up" the line-drive power, by running EMI noisy rotary drills, AC/DC motors-and-pumps (circulating water at 100 GPM), nasty switching supplies and so on... to get the noisiest, crappiest power I can achieve ... and sure enough - really good regulators isolate all of it, regardless of input transformer. But, in top-of-chassis mounted tube circuits, I've noted (as another poster hinted) that there can be a remarkable amount of influence from a power-supply transformer on the electron-cloud of both low-signal early-stage tubes, and the power/output tubes. Shield-cans on the tubes is remarkably helpful, if made of Mu metal, but having fully-enclosed cans on the transformers and good Faraday shielding seems to make an equally important (and audible) contribution. GoatGuy |
| power supply bypass cap size | BigE | Power Supplies | 11 | 5th July 2011 02:59 PM |
| Power Supply Case Size | diymixer | Power Supplies | 1 | 10th October 2010 05:47 AM |
| Cheap Valve Preamp power supply? | owenhamburg | Analog Line Level | 0 | 10th January 2010 05:52 PM |
| What size power supply should I get for repair work? | spooney | Car Audio | 3 | 6th December 2007 11:50 PM |
| MOT valve power supply? | Kilowatt | Tubes / Valves | 6 | 10th December 2001 05:13 AM |
