Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th July 2011, 02:45 PM   #1
sakis is offline sakis  Greece
sakis's Avatar
Default shelf oscilating psu
simple as that ...
just seen the revox B251 power supply unit .... i may also post a schematic
that is actually a simple oscilator and more actually the circuit that was was used as an "inverter" inside the first "economic" lamp SL 18- SL25 from philips ( if memory serves properly )
only adopted to higher power ..
any comments about this circuit ? it doesnt feature none of super functions like PWM or PFC but still worked quiet well ...for long time ..
Question is asked since "we" normally power amplifiers ... not spaceships
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 25th July 2011, 02:53 PM   #2
sakis's Avatar
or it could be the other way arround
what could possibly go wrong when a circuit like that is used next to a high tech supply ?
i see no regulation and that i can live with .... anything else ???
Old 25th July 2011, 04:43 PM   #3
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
If the oscilator part is not to complex to make, I don't see nothing too bad about it. So what if it doesn't have regulation, really depends on application you need it for... But this days, IC are so cheap, I think I would still go with it, instead of only parts you see on schematic
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 28th July 2011, 08:27 PM   #4
sesebe is offline sesebe  Romania
If I'm right this power supply have some advantage. It is a resonant one, ZVS type, the current is sinusoidal and the harmonics are very low, so less noise to the amplifier.
A SMPS with IC need to be a resonant one to have the same shape of current and is not so easy to made.
Old 28th July 2011, 08:40 PM   #5
sakis's Avatar
i have seen this type of psu made before but failed all the time i think poor choise of transistors or make of transformer ... but since im going to repair the revox i might take alook to see if its possible to get some expirience from that .
i will post my results here ...
regards sakis
Old 12th January 2012, 10:11 PM   #6
Hello,
Any news with this power supply?
Old 12th January 2012, 11:39 PM   #7
ontoaba is offline ontoaba  Indonesia
ontoaba's Avatar
Hi, sakis.
For high power use, that self oscillating will need much bigger transistors to make it not breaking down at repetitive starting operating mechanism. While controlled switching PSU need much smaller switching transistors.
This transistor size differences will affecting many of its performance, efficiency, speed, and cost, so there are few people using that type of self oscillation in high power.
Old 13th January 2012, 02:07 PM   #8
Hi Sakis,
those pioneering Philips energy saving lamps didn't feature any electronics at all, they simply were miniaturized switch-start fluorescent lamps with in-built chokes, which made them so heavy (about 1 pound).
Modern economic lamps feature inverters comparable to your schematic.
Best regards!
Old 13th January 2012, 05:23 PM   #9
jitter is offline jitter  Netherlands
jitter's Avatar
Indeed, those first generation energy saving lamps had magnetic ballasts. They earned the nickname "jam jar" in Holland.
The circuitboard in the attached picture does show similarities to the left part of Sakis' schematic.
The pic, BTW, is of an end of life CFL from a well known Dutch department store, but it's acually a Philips Genie CFL.
How to create self oscilating SMPS luka Power Supplies 10 7th January 2007 06:41 PM
Aleph P oscilating or something else!!! bbakota2000 Pass Labs 4 30th August 2004 04:17 PM
Looking for self oscilating class D lumanauw Class D 14 2nd March 2004 03:14 PM
And what about those shelf systems? r_s_dhar Everything Else 2 1st December 2003 10:18 PM
oscilating in capacitive load borisov57 Solid State 3 24th January 2003 12:29 PM
Page generated in 0.10107 seconds (81.57% PHP - 18.43% MySQL) with 11 queries
