Go Back   Home > Forums > Amplifiers > Power Supplies
Old 20th July 2011, 09:04 AM   #1
sekhar is offline sekhar  India
Default TO USE OR NT USE SNUBBER IN SMPS
i have made the given smps and it works fine ......... but in the original schematics the snubber was 470E & 102pf for a frequency of 50khz.
but i have increased the frequency to 90khz and the given snubber burns up . so how do i calculate the the new snubber. And the smps works even with out the snubber..........
help me with some formula with which i can calculate the snubber.......
regards
sekhar
Old 20th July 2011, 12:23 PM   #2
Going from 50 to 90 khz will almost double the snubber resistor loss, assuming constant rise time and no ringing. The snubber is chosen for rise time and and stray inductance. Also the snubber only needs to draw current until the body diode in the mosfets Q2 and Q3 have chance to conduct during the converter dead time.
Without a detailed simulation it is difficult to calculate a snubber, get out the Oscilloscope and look for overshoot spikes, decrease the capacitor until they just start to appear if the resistor is still smoking then use a higher wattage device or consider using external fast recovery diodes instead of the mosfet body diode.
If there are no large overshoot spikes then the snubber is probably unnecessary.
It would help if you can measure the dv/dt at point 5 during switching and the current in the DC link.
Orion NT Repair AcuraTLSQ Car Audio 0 29th March 2011 12:22 PM
[SG3525 smps] Input capacitors puffing after adding snubber aliazhar Power Supplies 36 21st November 2009 08:59 AM
SNUBBER resistance burns out in seconds(SMPS) sagarverma Power Supplies 22 26th June 2006 04:21 AM
test -NT- tiroth Everything Else 0 11th September 2002 06:31 PM
Page generated in 0.06753 seconds (67.46% PHP - 32.54% MySQL) with 11 queries
