Only had one spare but unfortunately does not appear to be the issue.The only things left are Q202,Q203 and the pot which tests fine.😕🙁Q205 Jfet remains to see about then.
😕 I hope you will not change all semis and it will be a joint or something trivial in the end. But you got to change all semis first unfortunately.
Voila. Changed fet's around and Q203 may have been the culprit,also retouched solder joints they all looked good but one may have been bad.
Thanks Salas for the responses.
Is there a recomended type leds for this project or anything goes
I will be glad If someone can recommend specific part on sale at Farnell
20ma ones, red 1.8fv, green 1.9fv or yellow.
Guys, will I be able to set the shunt at 9-10V, 650-700mA using the 3-led version of the board?
I recall reading the 4led one is better for higher currents.
Use IRF9620, 3 green LEDs, 1.2R 3W resistor. Has the benefit that 9620's zeroTC curves cross point is smack on your mA region and will make an exceptionally steady CCS.
It's not constant. In fact it's a USB transport.
It sits at about 125mA idle, 400mA at 9V and full load (aka playing 24/192).
I've used some other drivers that let it go up to 32/384, so I assume it'll need a bit more current when playing up there. I'm assuming 500mA full load to be on the safe side.
Thanks Nick!
Thanks Nick!
700-750mA will be hot-rod most of the time and will work high rev. Low impedance and best subjectively. Not too many Volt, you will sink it well, and will be A OK.
See the real current you will get with your individual components tolerances and trim the resistor value a bit up if in excess. I gave you ballpark value as always with Mosfets and LEDs.
thank you
are that one good http://www.farnell.com/datasheets/79375.pdf
It Is orange ?
The one's I distribute are red, a little lower forward voltage, green, a little higher, and sometimes yellow - a little in between. Orange looks to fit into that ballpark as well. With the newer boards with 4 LED CCS, just one color (red) will do IMO.
That's a strange looking LED, kinda like a RCA plug
I consider multi-comp a good brand.😀
Voltage reg now powering the BA-2 front end. Same set up as for the BA-3 although the BA-2 draws less current.
Because there is only 4-5cm between the reg and the front ends I have not used the twisted wire output configuration. There isn't room. So I have joined the two 0V on each rail and each of these is connected to the star ground of the main power supply which powers the output stage. +ve and -ve terminals on each rail are also connected on the reg board and then each is connected with a single wire to the -ve and +v terminals of the front end.
The BA-2 has up to now been running without a reg so tonight was the first time I heard it with the regulator in place. I will update you when I have had a chance to listen to some familiar pieces of music.
I just made the first test with my bib psu.
The goal is to get out 45VDC to drive my jfet phono pre.
I used 10R for R101, 6k8 R103, 5k poti and 560R test load.
The input was at 36.6VAC.
Before R101 46.7VDC, after R101 44,6VDC and on the output max. 39.5VDC.
Any hints to reach higher output voltage?
Merry christmas
Franz
Merry christmas
Franz
... I forgot to mention:
I used a test tranny, marked as 32VAC but measured 36.6VAC.
But I will try a "real" 36VAC tranny asap.
Franz
Franz
- Power Supplies
- SSLV1.1 builds & fairy tales
