#2041 |
I do. I have oscillations! I should have checked that first.
Lowering R7 makes them worse. The output cap changed to 100uF improves things but only loading the supply down so that 100 mA is shunted by the transistor makes it go away... and then the voltage is stable. I varied the output cap from 47uF to 1800uF and found 1800 to be much worse. 100uF is best. Here are my choices as I see them: I can now run the CCS at 500 mA, let my circuit draw 100 mA and add a resistor to draw 300 mA. Then the shunt transistor will dump 100 mA. Or, lower the CCS to 200 mA. The other option is to build another positive regulator and use it for the negative supply by connecting the positive output to ground. I have all isolated supplies so that will not be a problem. What do you recommend? |
#2042 |
diyAudio Chief Moderator
What kind of caps are installed on rails at load side? Since its oscillations with the load, maybe more R value in R7 for damping, or 0.1R in series with the load to buffer it.
#2043 |
The oscillations occur with or without the load. I am using just a resistor to simulate the load. My actual circuit that will be the load is currently being built.
The variable seems to be the amount of current through the shunt transistor. I do not think that buffering the load will help but I will alter the value of R7 and see how that works. It may be that I need to use all positive regulators to run the amount of current that I want to. That will be a lot more work to do because my heatsink will need to be drilled and tapped for the positive circuit board. Thanks for your help. Bill |
#2044 |
You talked about varying load and I thought something real. But you did not mean dynamically so. Just changing consumption. Got it. How is it at 200mA spare?
#2045 |
Sorry for any confusion. At 200 mA via the shunt transistor it oscillates. I have been checking out my positive regulator with the oscilloscope and it is rock stable at any load.
At this point, I plan to build more positive regulators and use them for the negative power supply. Do you think that there is a problem with that? My transformers and diodes are all separate for the positive and negative side. Bill |
#2046 |
I don't think its that different to the positive. I will have a closer look with the currents you refer and let you know more.
#2047 |
P.S. Are your builds p2p or on PCBs?
#2048 |
I am using the circuit boards from tea bag.
One of the FET's has g shorted to d instead of s. Changing that did not make a difference. Bill |
#2049 |
Try 100 Ohm gate stoppers on the 610s.
#2050 | |
| Frugel-Horn Mk3 Builds & Build Questions | planet10 | Full Range | 814 | 10th May 2013 04:20 PM |
| Call for MyRef-C Builds & Photos | bcmbob | Chipamp | 0 | 1st October 2010 10:57 PM |
| "Magga Amp Workshop" builds again (Simple 45 Project) | Niila | Tubes / Valves | 1 | 3rd February 2009 08:51 PM |
| so who here builds amps | amp builder jb | Tubes / Valves | 29 | 15th July 2005 08:23 PM |
