Go Back   Home > Forums > Amplifiers > Power Supplies
Old 12th December 2012, 12:32 PM   #2031
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Depends on your application. If its a line stage down to 4u7 PP can sound cleaner than electrolytics, but if it is an MC phono or a sensitive digital clock with no good PSRR you would need to filter the Vref hard to minimize noise with a 220uF for instance. Its discussed in the manual.
Old 12th December 2012, 12:42 PM   #2032
thank you Salas
I have In my Vref filter based on Leds 220 nF only and hear low level buzz but I doubt It Is from low value cap
Old 12th December 2012, 01:29 PM   #2033
Salas's Avatar
Buzz is usually some gnd loop nested somewhere in the full system. Takes tedious debugging. Also check with scope that the rail isn't acting up on something. Low Vref filtering for a purpose would demonstrate as higher white noise effect.
Old 12th December 2012, 06:54 PM   #2034
thank you
BIB Is high quality universal regulator
I see that some users hype 1.2R regulator - can It be set for 5 to 24 Vdc
which sounds better
Old 12th December 2012, 07:38 PM   #2035
Salas's Avatar
Not necessarily, I know people who prefer 1.1 and others the Reflektor. They all got their best synergy applications area, and subjective preference is a non quantifiable term.
Old 14th December 2012, 02:04 AM   #2036
Hi Salas,
I have built several positive and negative regulators using the recommended boards. I have noticed that the negative regulators do not have stable output voltage with respect to varying loads at high shunt currents (4-500mA through the shunt). Do I need to adjust some components or should I lower the current source to allow 100mA or so through the shunt? My load is 100mA and I currently am running 600mA from the current source.
Please advise.
Thank You,
Bill
Old 14th December 2012, 03:17 PM   #2037
Salas's Avatar
Much spare current slips the phase margin more with the semis used in the negative polarity. Solder another 1 Ohm across the R7 to see if something changes. But first check the rail with the scope to see there is no oscillation issue giving the instability. If its a DC line without waveforms riding and lessening R7 does not help, stick a 100 uF across the sense terminals on output connector. Last resort is you try use significantly less spare current.
Old 15th December 2012, 11:37 AM   #2038
Default best film type cap that BIB can handle
I am looking to buy some films for Vref and Vout
I am struggling between Auricap and Sonicap
would you recommend which can be better to power line aplication - UGS V3
of course you can recommend some other brand
I would like to use Obbligato Gold but It Is so long
Old 15th December 2012, 02:41 PM   #2039
Thank you for the recommendations Salas.
Lowering the resistor at R7 to 1/2 Ohm and then shorting it out both improved the change in voltage. Shorting out R7 was better. My current output cap is a 10uf film (C104). 100uf across the output causes the voltage change with varying loads to be insignificant. I will experiment with different output capacitors in place of my current 1 Ohm/ 10uF film Zobel.
Another possibility is to add some electrolytics to the circuit that I will be powering and leave the Zobel in place on the regulator circuit board.
My final choice is to lower the current sours down to 200 mA but I like to run it hot.
Am I on the right track??
Bill
Old 15th December 2012, 02:43 PM   #2040
Salas's Avatar
You are on the right track. Do you have an oscilloscope?
Frugel-Horn Mk3 Builds & Build Questions planet10 Full Range 814 10th May 2013 04:20 PM
Call for MyRef-C Builds & Photos bcmbob Chipamp 0 1st October 2010 10:57 PM
"Magga Amp Workshop" builds again (Simple 45 Project) Niila Tubes / Valves 1 3rd February 2009 08:51 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
Copyright ©1999-2013 diyAudio
