Go Back   Home > Forums > Amplifiers > Power Supplies
Old 30th November 2012, 03:22 AM   #1991
Rush is offline Rush  United States
Originally Posted by qusp View Post
the impedance of the transformer is hardly going to be the dominant impedance in a preamp is it?
Yes, the impedance of the transformer is reflected.
I didn't come to this conclusion through any kind of math, I tried transformers with fatter wires in them (more current capable or another way of thinking, low impedance) and yes you can hear a difference.
Try it, buy a transformer of the same voltage as you would normally use, only 5 to 10 times the amp rating for your preamp.
You will be hooked on the silly size.
Whatever problems this creates you will work through and be glad you did.
And the caps don't hardly discharge on a preamp while your using it, so your over thinking this.
Rush
PS, Of course this is my opinion and if I am wrong, prove it by testing it, not by math or thinking about it.
Old 30th November 2012, 04:07 AM   #1992
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
No, it really isnt, the dominant impedance is that of the local regulation and decoupling, of the consumer, if you are relying on having a low impedance transformer (in another case on the end of a cable) to deal with short term local current demand in a low current, low noise circuit, youve got it backwards.
I really dont need to prove anything to you, you are the one making the claims
you are suggesting I need to replicate your preamp and power supply to prove you wrong?... lol
thats even if you assume thats my motivation...
Old 30th November 2012, 04:16 AM   #1993
No, it really isnt, the dominant impedance is that of the local regulation and decoupling, of the consumer, if you are relying on having a low impedance transformer to deal with short term current demand in a low current, low noise circuit, youve got it backwards.
Now you are thinking instead of finding out for sure.
I have done the test, I am sure.
Rush
Old 30th November 2012, 04:18 AM   #1994
Rush
If YOU look at where the current really flows, then you will know for sure.
Now you are just imagining where the current flows.
What is the purpose of the capacitor in your circuits?
Old 30th November 2012, 04:33 AM   #1995
I have no idea what your are referring to.
So you have tested a larger transformer vs a smaller one? And found what?
Are you thinking or doing?
Rush
Old 30th November 2012, 04:39 AM   #1996
Rush
I think before I build. I also think before I write. People these days will find any excuse to avoid thinking, it seems.
Old 30th November 2012, 04:39 AM   #1997
qusp's Avatar
I updated my post which you may not have seen. your transformer is even in another case! assuming any transformer we are talking about has more than enough capability to power the circuit, you expect having a lower impedance larger transformer makes any difference at the end of a cable, perhaps a connector or 2, your rectifiers and smoothing/ CRC/ CLC/ or inductors? really?
no; local regulation and decoupling is supplying transient current demand, not the transformer
Old 30th November 2012, 04:43 AM   #1998
You win, I am done.
Don't try it, you wouldn't like it anyway.
Rush
Old 30th November 2012, 04:57 AM   #1999
I updated my post which you may not have seen. your transformer is even in another case! assuming anything we are talking about has more than enough capability to power the circuit. you expect having a lower impedance larger transformer makes any difference at the end of a cable, perhaps a connector or 2, your rectifiers and smoothing/ CRC/ CLC/ or inductors? really?
Hey, thats not fair changing the post after I replied. :-)
This is just what I have found.
Please tell me, should I have not brought it up?
I surely don't want to make someone angry, it is just so easy to dismiss the idea without trying it.
So why do you bother dismissing the concept, if at least I think it sounds better?
I first found this out with a Threshold FET 10 preamp. Built power supplies for my local audio store that he then sold to his best customers with this preamp. We all had fun and it made the preamp better. Go figure!
I am not going to defend this anymore. You guys are smarter than I am, you can think all the good stuff right into your projects and you surely don't need some 60 + year old reminiscing about simple things that made a difference a long time ago.
Rush
Old 30th November 2012, 04:59 AM   #2000
You win, I am done.
Rush
It isn't about winning; its about do/design it yourself audio. A few people have pointed out where you should be looking/thinking about your design choices differently.
For a power amplifier with a linear supply, there is a point to a larger transformer, though in that case it is often more important to get the power supply capacitance correct and electrically close enough to the load.
For a line stage circuit with a shunt regulator, there is very little point to an oversized transformer. It is not the part of the circuit that supplies the current to a transient load.
Frugel-Horn Mk3 Builds & Build Questions planet10 Full Range 814 10th May 2013 04:20 PM
Call for MyRef-C Builds & Photos bcmbob Chipamp 0 1st October 2010 10:57 PM
"Magga Amp Workshop" builds again (Simple 45 Project) Niila Tubes / Valves 1 3rd February 2009 08:51 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
Copyright ©1999-2013 diyAudio
