Go Back   Home > Forums > Amplifiers > Power Supplies
Old 2nd November 2012, 07:17 PM   #1881
Originally Posted by Salas View Post
This type? I measured enough dissipation VS MKP but subjectively they were high class.
which Is that jupiter
which mkp do you recommend to use with BIB
Old 3rd November 2012, 01:18 AM   #1882
schubert's Avatar
Here's some pics of my B1 before and after installing the SSLV, and a closeup of one of the Jupiter output caps.
Old 3rd November 2012, 01:21 AM   #1883
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Very classic Scandinavian like box. I like.
Old 3rd November 2012, 01:23 AM   #1884
Salas's Avatar
That Jupiter is their current brown skinned higher temp line. Use something like Multicap in the Zobel.
Old 4th November 2012, 05:51 PM   #1885
jimchan is offline jimchan  Norway
Default Dual Polarity Salas
Originally Posted by AndrewT View Post
I have been trying to persuade the Group Buyers to adopt a single PCB for both the -ve and +ve regulated supplies.
With care, any of the existing PCBs can be converted to the other polarity.
I would rather buy all the PCBs identically and use the build manual to guide me to achieving which polarity I require.
But even that complication is not always required.
Simply build all -ve regulators and use a dual secondary to power the regs. This gives an equal or better performance Dual polarity regulated supply than having to buy specialised +ve & -ve PCBs and having the problem of "left overs".
Hi Andrew / others,
Newbie here : I am building two Salas boards to create -12v 0v +12v output to power an Opamp.
Can I 'just' connect the 0v from the two boards to create a reference 0v ? or will I get current drawn from one to the other (ie: short circuit situation).
I have only single transformer 15 output to feed both boards.
Thx
Jim.
Old 4th November 2012, 06:31 PM   #1886
Marra is offline Marra  United Kingdom
Its all in here
https://docs.google.com/document/d/1...CM7d-IkL&pli=1
Old 4th November 2012, 06:31 PM   #1887
Hi, I kept building 3 boards in a row . My boards power TP's Opus DAC and the transceiver board. As a Vref cap, Oscon was replaced soon. Weren't a good choice there. SSLV1.1 works well, I like it very much! C105, C103 caps are Nichicon Muse KZ's: 1000 uF/25 V and 47 uF/25 V.
The schematic is OK. Shows an optional Zener also that may had tricked you. Objectively yes, OSCON is a good filter. Subjectively not my preference there.
Old 4th November 2012, 08:07 PM   #1888
Salas's Avatar
Final success PSU+client application system picture we like to see as always.
Old 5th November 2012, 08:43 AM   #1889
Thanks Marra,
My transformer is dual secondary, feeding 15v to each Salas board. I get nice 13v output from each board.
To make a dual polarity PS, I assume the 0v from each board should be made common (?). Should the common 0v also be grounded ?
Old 5th November 2012, 08:55 AM   #1890
Salas's Avatar
If your client circuit board has a common point, there they go the F0 S0 wires from both boards and they make a symmetric system. Grounding to chassis or not its a matter of how your design is sorted out and what is recommended, i.e floating or not there.
Frugel-Horn Mk3 Builds & Build Questions planet10 Full Range 814 10th May 2013 04:20 PM
Call for MyRef-C Builds & Photos bcmbob Chipamp 0 1st October 2010 10:57 PM
"Magga Amp Workshop" builds again (Simple 45 Project) Niila Tubes / Valves 1 3rd February 2009 08:51 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
