Go Back   Home > Forums > Amplifiers > Power Supplies
Old 15th April 2012, 12:31 PM   #1041
AndrewT is online now AndrewT  Scotland
I much prefer higher value resistors soldered in parallel. The original DCB1 could accommodate six //Rs for each CCS.
Then it is cheap and easy to increase CCS current by adding extra resistors and no de-soldering required. If the heat proves to be too much, then that last addition can be snipped off.
How does voltage regulator sense work into some other manufacturer's product?
Old 15th April 2012, 12:33 PM   #1042
I agree.
It'd be a good idea to have provisions on the PCB for installing resistors in parallel.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 17th April 2012, 11:41 AM   #1043
Siberia is offline Siberia  Lithuania
Siberia's Avatar
I want to use SSLV 1.1 for feeding 28VDC to my future Pearl II RIAA. Getting a 2x24 R-Core, I would get around 26VAC on my Tx secondaries because of local mains, and 26 X 1.33 = 34,5VDC after rectification. Is it enough for an extra voltage? Or are two 2x15 R-Cores recommended for bigger DCin?
Old 17th April 2012, 11:46 AM   #1044
No.
How many times does it need to be repeated that the Salas Style Regulator needs >=7V across the CCS?
Old 17th April 2012, 12:05 PM   #1045
Siberia's Avatar
I'm aware what's written in the guide. It says, at least extra 5V, but 7-10V recommended. The reason I'm asking this because i get <7V across, but with two 2x15 I would get into 45VDCin, which may be too much for cooling it down. All I wat to know which way is prefered.
Old 17th April 2012, 01:36 PM   #1046
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Burn as much as you want on a CRC pre filter so you have control and extra filtering? Longer pants have always the better chance to get cut to measure.
Old 17th April 2012, 01:42 PM   #1047
Originally Posted by Siberia View Post
7-10V recommended. The reason I'm asking this because i get <7V across,.........
Have you checked what DC voltage with ripple voltage superimposed that will appear at the regulator power input when the mains voltage swings over the range from maximum supply to minimum supply?
It is the voltage amplitude at the minima due to the ripple that determines the worst case Vin at the regulator.
Old 17th April 2012, 02:41 PM   #1048
Siberia's Avatar
Originally Posted by AndrewT View Post
Have you checked what DC voltage with ripple voltage .
No.
I admit that I don't know the maths behind it, but would love to know how you do it.
Explaining that it's
is not enough for my knowledge level. Sorry.
Then I just realised that I would better use Pear II, omitting onboard regulator and feeding it with 24VDC of SSLV 1.1 Tx 2x24VAC is about right then for the purpose.
Old 17th April 2012, 02:47 PM   #1049
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Siberia, I am using 2 x 24v transformer with Pearl2 onboard reg removed.
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE
Old 17th April 2012, 03:08 PM   #1050
Siberia's Avatar
OT. Quick question. I'm planning to remove U1, U2, and to replace them with 10R resistances making an additional CRC filter. I would connect shunt. reg. after this filter. Is that the way yours is made?
Frugel-Horn Mk3 Builds & Build Questions planet10 Full Range 814 10th May 2013 04:20 PM
Call for MyRef-C Builds & Photos bcmbob Chipamp 0 1st October 2010 10:57 PM
"Magga Amp Workshop" builds again (Simple 45 Project) Niila Tubes / Valves 1 3rd February 2009 08:51 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
Copyright ©1999-2013 diyAudio
