SSLV1.1 builds & fairy tales
Old 6th February 2012, 09:48 PM   #971
merlin el mago is offline merlin el mago
merlin el mago's Avatar
OK
Old 8th February 2012, 01:42 PM   #972
Default SSLV1.1 vs SSLV1.2R
SSLV1.1 is far better than SSLV1.2R, I compared in my Simplistic NJFET RIAA first powered with 2 tx & 2 SSLV1.2R vs now 1 tx & 1 SSLV1.1, I tried Vref 10uF MKP & 220uF Pana FM: MKP more harmonics so more definition, lytic more body so more mids and lows, both have an excellent midrange & bottom end perhaps MKP is more crystal clear but all depends every personal taste to decide wich one is the best in each system.
I believe that the big upgrade is in the mids & lows areas also is far more 3D sound, Salas if you did the same with SSHV2 will be perfect for my taste.
Old 8th February 2012, 02:36 PM   #973
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Don't forget that V1.2 is very sensitive to layout for performance.
Did you check it with a scope?
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 8th February 2012, 02:38 PM   #974
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
There is some feedback by Stixx and vgeorge regarding the subjective evolution of the high voltage ones in their thread. One thing about 1.1 for sure is that is released as a controlled layout pcb item, as intended and tested by me. I intentionally don't overengineer wide circulation regs because they tend to be difficult to work best with many loads and need many learned checks system wise regarding their phase margin. Edge specs are not everything IMO, and too high an open loop gain sounds ''stiff'' to me with most client circuits even when the colaboration is smooth.
Old 8th February 2012, 02:40 PM   #975
I did V1.2R and not checked with a scope.
Old 8th February 2012, 02:43 PM   #976
Salas's Avatar
Stick to 1.1, its most easy to succeed in most cases and is well balanced for wide application.
Old 8th February 2012, 02:44 PM   #977
Will see how works SSHV2 with the 26 preamp, Puresound P10 RIAA & Valve Itch, if it reach the same level of perfomance that you will reach with SSLV1.1 worth the work & the money
Old 8th February 2012, 02:44 PM   #978
vgeorge's Avatar
Then, there is always the chance that you have an oscillation, not that you do, but can' t be sure otherwise.
Old 8th February 2012, 02:49 PM   #979
Salas's Avatar
vgeorge had both 1.2R and bib on his phono, did you hear the differences that Merlin describes, George?
Old 8th February 2012, 03:05 PM   #980
acidbrain is offline acidbrain  Netherlands
acidbrain's Avatar
LOL, later on I can give the results between my XONO powered bij the SSLV1.1 vs DCB1 with remote sense.
SSLV1.1 builds & fairy talesHide this!Advertise here!
Legis' Horny Tales Legis Multi-Way 176 11th September 2017 12:21 PM
Any successful/unsuccessful tales of loading a large Coax in a front horn? POOH Multi-Way 35 22nd November 2015 08:58 PM
Fs: Salas SSLV1.1 BIB janos_904 Swap Meet 13 27th May 2015 08:36 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
