SSLV1.1 builds & fairy tales
Old 2nd February 2012, 10:17 AM   #921
Backbones is offline Backbones  United Kingdom
One would have thought that a voltage regulator with very low noise would not worry too much about its smoothing caps. Well it isn't so. I initially used some fairly cheap but serviceable Panasonic 10,000uF TS-HA caps. Listening to the BA-2 with these in the regulator for the front end I was initially pleased with the overall clarity improvements, however, turning to some of my favourite music such Healy-Hutchinson carol piece I was struck by the lack of comfortable warmth and the rather flattend perspective of the orchestra. Could it be the caps. I had a nagging feeling I should have used my favourite Mundorf AG in the first place but how could caps this far back from the output make such a difference? Out went the 10,000 and in came the 4700uF Mundorfs. Well the difference is very significant. Flattened soundstage and I have to say somewhat flattened musical images have much more depth. Strings now can be heard with more warmth and depth positioned more clearly behind the brass for example. Could it be 10,000 to 4700uF made the dirrerence. Well possibly but I have noted the characteristic of these Panasonics before and for me they don't sound as good as the Mundorfs, which is a shame really because they are a lot cheaper.
Chris
Old 2nd February 2012, 10:29 AM   #922
acidbrain is offline acidbrain  Netherlands
acidbrain's Avatar
Panasonic caps lack some bass & warmth but are good in mids & highs + very reliabable. I don't know the Mundorfs AG but it's boutique and "dressed" for audiopurposes, so us the price My experience is if big caps aren't needed don't use them, more speed and less heavy sound. What about the burn-in proces, did you gave the TS-HA time for that ?
Caps are like spice to me.
Old 2nd February 2012, 10:33 AM   #923
R.I.P.
Did you check the PSU rail stability before and after the mods?
Did you check the amplifier stability before and after the mods?
regards Andrew T.
Old 2nd February 2012, 10:33 AM   #924
Yes, plenty of burn-in time. The Mundorfs don't always do it for me. I tried a 10,000uF 25V on several projects and it always sounded constrained, lacking the usual openess I associate with Mundorfs.
Yes, there is something addictive abouts caps.
Old 2nd February 2012, 10:34 AM   #925
Can you take me through those steps please Andrew?
Chris
Old 2nd February 2012, 10:40 AM   #926
R.I.P.
Stick a scope on the power rail.
Start applying some horrible signals to the amplifier. Does the PSU rail react?
regards Andrew T.
Old 2nd February 2012, 10:55 AM   #927
Horrible signals to the amp--are we talking Stockhausen--and what is the reaction I should be looking for on the scope?
Chris
Old 2nd February 2012, 10:58 AM   #928
R.I.P.
Loud music or quiet squarewaves, or loud filtered squarewaves or etc.
The PSU should show a tiny rounded sawtooth ripple at quiescent.
This ripple should increase in value, but not in shape, as the output current goes up towards maximum.
regards Andrew T.
Old 2nd February 2012, 07:53 PM   #929
alazira is offline alazira  United States
alazira's Avatar
Chris
From my own cap-swapping experiments:
The 10,000uF (mundorf AGl, nichicon KG) sounded better than their corresponding 4700uF or 6800uF versions.
My favorites:
1) Mundorf AG
2) Panasonic TS-HA
3) DNM/BHC 2 pole slit foil (very smooth warm sound; many will prefer this)
4) Nichicon KG
Old 2nd February 2012, 08:41 PM   #930
My favorites:
Hadn't come across this one before; it certainly looks interesting.
Thanks.
SSLV1.1 builds & fairy talesHide this!Advertise here!
Legis' Horny Tales Legis Multi-Way 176 11th September 2017 12:21 PM
Any successful/unsuccessful tales of loading a large Coax in a front horn? POOH Multi-Way 35 22nd November 2015 08:58 PM
Fs: Salas SSLV1.1 BIB janos_904 Swap Meet 13 27th May 2015 08:36 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
