SSLV1.1 builds & fairy tales - Page 83 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 8th December 2011, 12:24 AM   #821
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Q205 Jfet remains to see about then.
Old 8th December 2011, 01:10 AM   #822
F1 FAN is offline F1 FAN  Canada
Only had one spare but unfortunately does not appear to be the issue.The only things left are Q202,Q203 and the pot which tests fine.
Old 8th December 2011, 01:34 AM   #823
Salas's Avatar
I hope you will not change all semis and it will be a joint or something trivial in the end. But you got to change all semis first unfortunately.
Old 8th December 2011, 02:05 AM   #824
Voila. Changed fet's around and Q203 may have been the culprit,also retouched solder joints they all looked good but one may have been bad.
Thanks Salas for the responses.
Old 10th December 2011, 04:15 PM   #825
Is there a recomended type leds for this project or anything goes
I will be glad If someone can recommend specific part on sale at Farnell
Old 10th December 2011, 04:55 PM   #826
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
20ma ones, red 1.8fv, green 1.9fv or yellow.
Salas Boards GB 2017#1 ON ORDER | GB 2017 #2 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards On ORDER
Old 11th December 2011, 09:05 AM   #827
Guys, will I be able to set the shunt at 9-10V, 650-700mA using the 3-led version of the board?
I recall reading the 4led one is better for higher currents.
Old 11th December 2011, 09:20 AM   #828
Salas's Avatar
How much from that will go to the load?
Old 11th December 2011, 09:32 AM   #829
Salas's Avatar
Use IRF9620, 3 green LEDs, 1.2R 3W resistor. Has the benefit that 9620's zeroTC curves cross point is smack on your mA region and will make an exceptionally steady CCS.
Old 11th December 2011, 09:32 AM   #830
It's not constant. In fact it's a USB transport.
It sits at about 125mA idle, 400mA at 9V and full load (aka playing 24/192).
I've used some other drivers that let it go up to 32/384, so I assume it'll need a bit more current when playing up there. I'm assuming 500mA full load to be on the safe side.
Thanks Nick!
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1639 20th June 2017 02:19 PM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 05:34 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
Copyright 1999-2017 diyAudio
