SSLV1.1 builds & fairy tales
Old 7th December 2011, 12:43 AM   #801
F1 FAN is offline F1 FAN  Canada
Oh snap my negative 12 volt reg. is now sitting at -26 and will not adjust down with the pot.A quick check showed neither the IRF610(Q201)nor MJE15030(Q206)appear shorted.Any guidance as to where to start looking?
Old 7th December 2011, 12:57 AM   #802
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Look if Q201,206 show few volts between their G,S pins each. For 206 BJT look for ~0.6V between B,E.
P.S Check BC560 for 0.6V between B,E also.
Old 7th December 2011, 01:15 AM   #803
-5.5v between Q,S on Q201 nothing between B,E of Q206 and only about 0.13v between B,E of BC560.
Old 7th December 2011, 02:35 AM   #804
coolhead is offline coolhead  Malaysia
F1 fan, how does it happen? Is it over heated?
Old 7th December 2011, 02:42 AM   #805
Everything ran cool,as you can see in the pic in post#772 i used the chassis as heatsink.
Old 7th December 2011, 05:48 AM   #806
Salas's Avatar
Change 560, test, then Q201.
Old 7th December 2011, 08:54 AM   #807
superluca71 is offline superluca71  Italy
Finally i've finished my first BiB....
It will supply a v-dac II.
output 14v
R101 2.7ohm + 3 green leds
Voltage across resistor is 0.90 v
for circa 0.340 ma...
is it good?
I'm using a 18v 60va transformer
Old 7th December 2011, 09:58 AM   #808
merlin el mago is offline merlin el mago
merlin el mago's Avatar
output 14v
is it good?
mA or A?
How many current draws v-dac II?
Old 7th December 2011, 10:05 AM   #809
sorry 300ma!
i think it draws about 200 / 250 ma...
i've measured with the tester non more than 200ma for about 30 minutes...
i think my setting would be fine...
what you think about?
Old 7th December 2011, 10:12 AM   #810
Left 100mA more of headroom: 350mA
Current don't change with time, only change the voltage with time.
Cari saluti
SSLV1.1 builds & fairy talesHide this!Advertise here!
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1653 8th December 2017 08:26 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 10:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 10:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 06:34 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 09:23 PM
Copyright ©1999-2017 diyAudio
