SSLV1.1 builds & fairy tales - Page 8 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 30th July 2011, 10:05 AM   #71
Hello,
I also I have regulators to feed a buffalo dac. I sign the recommendation for R1.
For an output of 15.5 volts and a simulation of 450 ma, what I recommended load resistance?
Same for 5.5 volts and 450 ma.
Old 30th July 2011, 11:07 AM   #72
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Say you got one result like in post 68, then it will be 3R3 (+) and 2R2 for (-). Its Ohm's law. You see the voltage drop, you calculate V/R. Its in the guide.
Old 30th July 2011, 01:39 PM   #73
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
I use 3.3R in my 15v one, I forgot what we calculated the current to be.
The R1's don't get crazy hot.
Salas Boards GB 2017#1 ON ORDER | GB 2017 #2 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards On ORDER
Old 30th July 2011, 04:49 PM   #74
I have some EVOX MMK 15μF from another project.
Can i use them for C102,202,302,104,204,304, or they are too big?
Old 30th July 2011, 06:47 PM   #75
Thank you very much for the answers.
I have already clear how to calculate R1. My question is about the dummy load resistor at the output. I guess for 5 and 15 volts and simulate consumption of 450 m is 12 ohms and 33 ohms respectively.
Old 30th July 2011, 06:53 PM   #76
Salas's Avatar
For value they are not too big.
Old 30th July 2011, 06:55 PM   #77
Salas's Avatar
They must be 33R 15W and 12R 5W to hold.
Old 31st July 2011, 09:53 AM   #78
First 5.5V out build is working!
568mA CCS, 30mV voltage drift, perfect clean output, no oscillations.
I noticed when tuning the CCS resistor, that the voltage across it is more with bigger resistor values and less with smaller resistor values.
For example:
12Ω resistor, 1.87V
2Ω2 resistor, 1.25V
Is this normal?
Old 31st July 2011, 10:16 AM   #79
Salas's Avatar
Vgs is a curve regarding current in Mosfets, so its normal. Looks good.
Old 31st July 2011, 02:43 PM   #80
Franz Gysi's Avatar
Work in progress for my psu for the simplistic RIAA
It will be a 45VDC supply.
BTW, Salas: how much current does my 15mA RIAA consume, what would be a correct load resistor to test the psu?
Franz
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1638 22nd May 2017 10:11 PM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 05:34 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
Copyright 1999-2017 diyAudio
