SSLV1.1 builds & fairy tales - Page 63 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 20th October 2011, 06:19 PM   #621
merlin el mago's Avatar
I don't understand, could you elaborate?
Old 20th October 2011, 06:19 PM   #622
Originally Posted by merlin el mago View Post
Extracted from leonvb BIII manual in the TP site:
"The standard board requires an input voltage of 5.25V and it draws approximately 440mA when one is using the recommended set of Trident shunt regulators"
I had the same problem with a repair manual for the Quad FM4 Tuner. It mentions current draw of 30mA. I found that it drew about six times that, 180mA. In the end I checked it using a power supply (no reg) with a C-R-C filter and measuring the voltage across the resistor.
Chris
Old 20th October 2011, 06:22 PM   #623
Salas was indicating the voltage drop across the green LEDs on the current setting circuit.
Old 20th October 2011, 06:24 PM   #624
I doubt that Russ or Brian left a wrong information in his web site, a lot of people buy his products but who knows "errarem umanum est"
Old 20th October 2011, 06:29 PM   #625
What was it the Sherlock Holmes said? Ah yes, "when you have eliminated the impossible, whatever is left, however improbable, must be the truth".
Old 20th October 2011, 06:37 PM   #626
Measured voltage across all 4 LEDs 7.48V
Old 20th October 2011, 08:04 PM   #627
With a dummy load 11 ohms (two 22R in parallel) reg gets 5.25Vout so 0.5A
Old 20th October 2011, 08:10 PM   #628
Connected again the B3 & still the same problem can't reach 5.25Vout
Old 20th October 2011, 08:32 PM   #629
What's the load consumption? If it's for BII or III here is the reason why sounds good...
It is for BII.
Old 20th October 2011, 08:40 PM   #630
This current have to be for a Trident, wich one XO, right?
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1634 31st January 2017 03:57 PM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 10:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 10:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 06:34 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 09:23 PM
Copyright 1999-2017 diyAudio
