SSLV1.1 builds & fairy tales
Old 20th October 2011, 04:46 PM   #611
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by Backbones View Post
So
What current is your transformer providing for each secondary? 30VA
What value have you for R101? 3R3
Four LEDs green, correct? YES
What is the voltage drop across each green LED? 1.8-1.9V
What value for C105? 10.000Uf
Chris
Old 20th October 2011, 05:01 PM   #612
Backbones is offline Backbones  United Kingdom
Transformer current sufficient.
4 times 1.9V = 7.6V
Say current draw of 700mA = Vgs of about 5.5V.
7.6-5.5=2.1V
I=V/R. I=2.1/3.3. I=640mA.
Not enough current for 700mA. R101 needs to be 3ohm or lower (2.1/0.7). I don't know up to what current the BiB is designed to go.
chris
Old 20th October 2011, 05:08 PM   #613
cersepn is offline cersepn  United States
Originally Posted by Salas View Post
Use 3 1.9V leds and 1.2R 2W setting resistor (R101 etc.) for 0.5A available if you can't find 1.3R.
Hmm, Salas just to confirm, 1.9V = RED LEDs, yes? Because i saw other people who used the regs in the same application and they used the green LEDs in Dx02,x03,x04 instead. Is it because their current used is different?
Old 20th October 2011, 05:09 PM   #614
R.I.P.
Originally Posted by coolhead View Post
Voltage across R301:
6.3Vac trans = 1.31V
9Vac trans = 1.36V
R301 is 10ohm
The output is the same 3.3V, the different will be CCS current of 50mA.
and now turn the mains supply voltage down to suppliers specified minimum. Measure again.
The fact that you have already lost 50mV tells me you are getting close to dropping out.
regards Andrew T.
Old 20th October 2011, 05:09 PM   #615
Measured voltage accross R1 2.37 V : 3R3 = 718mA
BTW enough for B3...
Old 20th October 2011, 05:11 PM   #616
Different voltage.
Old 20th October 2011, 05:13 PM   #617
OK. After calculation errors it is about the right current levels. The drop across the LEDs depends on their current I believe to some degree.
If you are supplying the right current at the reg level one has to ask if the load is drawing more than this?
Chris
Old 20th October 2011, 05:16 PM   #618
Chris
Extracted from leonvb BIII manual in the TP site:
"The standard board requires an input voltage of 5.25V and it draws approximately 440mA when one is using the recommended set of Trident shunt regulators"
Old 20th October 2011, 05:16 PM   #619
Looks 5ish to me, better calculate based on Vgs=5V. Also your LEDS maybe ~1.9V at the small current they will run, their spec voltage drop Vf is given at 20mA nominal usually.
From an earlier post.
Chris
Old 20th October 2011, 05:19 PM   #620
I don't understand, could you elaborate?
SSLV1.1 builds & fairy talesHide this!Advertise here!
Legis' Horny Tales Legis Multi-Way 176 11th September 2017 12:21 PM
Any successful/unsuccessful tales of loading a large Coax in a front horn? POOH Multi-Way 35 22nd November 2015 08:58 PM
Fs: Salas SSLV1.1 BIB janos_904 Swap Meet 13 27th May 2015 08:36 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
