SSLV1.1 builds & fairy tales
Old 12th October 2011, 12:36 PM   #521
Sergelisses is offline Sergelisses  France
Originally Posted by AndrewT View Post
It depends on what you require.
Output voltage and transformer voltage are only two parts of a much wider brief.
Thank you so much for your answer
Old 12th October 2011, 12:45 PM   #522
R.I.P.
Is the brief a secret?
regards Andrew T.
Old 12th October 2011, 12:55 PM   #523
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
AndrewT,
Are you referring to his trannies VA? I think you may have left you point too open ended.
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 12th October 2011, 02:02 PM   #524
Originally Posted by Sergelisses View Post
I plan to do two regulators : 3.3v and 5v and i have 2x12v transfo .
Is it too high ?
Serge
The question is can i use a RCore transfo 230v~ 2x12v~ ( 30VA) for the regulators 3.3v and 5v.
One 12v~ for the 3.3v and the other 12v~ for the 5v ?
Serge
Old 12th October 2011, 02:42 PM   #525
Backbones is offline Backbones  United Kingdom
Serge
If we multiply by AC output of your transformer by 1.4 we get the approx voltage DC your regulator will have to deal with, which is 16.8V. So we need to convert 16.8 to 3.3 and 5v so depending on the regulator type that will cause heat generation as it brings down the voltage. It is quite possible but would be more efficient if you brought the transformer voltage down. You need to include some voltage off for the diode bridge and allow some voltage headroom to operate the voltage regulator.
Chris
Old 12th October 2011, 03:38 PM   #526
R.I.P.
Backbones is quite new to this and already he has identified an area that has not been considered in the brief.
How can anyone think that 12Vac and 5Vdc is sufficient to start a design analysis?
regards Andrew T.
Old 12th October 2011, 04:13 PM   #527
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The brief says 5VDC drop is recommended across the reg, 6.3VAC min 36VAC max transformer. That should suffice.
Old 12th October 2011, 07:11 PM   #528
R.I.P.
******* Hell !
What about current demand?
What about power dissipation?
regards Andrew T.
Old 12th October 2011, 07:20 PM   #529
Salas's Avatar
Its mentioned in the guide. Appendix 6.
Old 12th October 2011, 07:25 PM   #530
R.I.P.
Is 200mA output current what he needs/wants?
Is he going to use a ventilated case or unventilated internal heatsinks or external heatsinks?
Both he and us need information from a brief to be able to start to answer the question
Is it too high ?
regards Andrew T.
SSLV1.1 builds & fairy talesHide this!Advertise here!
Legis' Horny Tales Legis Multi-Way 176 11th September 2017 12:21 PM
Any successful/unsuccessful tales of loading a large Coax in a front horn? POOH Multi-Way 35 22nd November 2015 08:58 PM
Fs: Salas SSLV1.1 BIB janos_904 Swap Meet 13 27th May 2015 08:36 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
