SSLV1.1 builds & fairy tales - Page 52 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 11th October 2011, 03:23 PM   #511
What have I started!
Old 11th October 2011, 03:25 PM   #512
Back,
how much effort to find out out if the current draw from the new PSU is constant, or nearly constant, or slightly variable or very variable?
Running the FM4 from an isolated supply and connect an earthed scope across the lower value of test resistor. Try 1r0 instead of 8r2. Keep your hands off while powered up.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 11th October 2011, 04:21 PM   #513
Sorry Andrew I don't have a scope.
I am only running the audio output and tuner section with the external supply. The FM4 transformer supplies the rest which includes the tuning freq display. In fact it will run on just the tuner and audio output only with the freq display blank.
Have you measured the current draw on yours?
Chris
Old 11th October 2011, 05:11 PM   #514
These are my thoughts after listening to the Salas BiB this afternoon.
This afternoon I finally plugged in the Salas BiB shunt regulator in to power up my old Quad FM4 tuner. The regulator is powered by an external toroid supply rated at 16VAC 1amp for each of its secondaries, only one of which is being used here. I listened first to a solo piano piece and what was immediately gratifying was an absence of glare from the piano notes. It is too easy to find piano notes sounding like wood blocks being knocked together and the resulting brittle glare is difficult to relax into. It also creates a two dimensional image but there was no sign of any of this with this setup; the absence of background noise allowed the dying harmonics inside the piano to be heard and the instrument was presented as a whole. With previous power supplies the piano often sounded an instrument of two halves, one connected with the right hand and another involved with the lower end of the keyboard. I think it is the ability to reveal the low level detail that allows the instrument to be seen as a whole. This ability to create a satisfying musical whole was apparent from BBC’s next offering.
Schubert’s unfinished was to follow played by the Scottish Symphony Orchestra.
Again the absence of background noise allowed individual instruments not only to be enjoyed in their own right with full and realistic dynamics but also to gel homogeneously with the rest of the orchestra. I have often listened to instruments appearing from the orchestra as though escaping from a dark background which is not unpleasant. But with the Salas in place the instruments can be heard against a background of other more subtle musical images such as quiet strings and woodwind. And these instruments don’t disappear at low sound levels so the musical image is held together as a unit. I haven’t enjoyed so much before the strings of the double basses and cellos holding their own as the rest of the orchestra joined. In the past they became lost in the overall sound but this power supply kept everything in focus. Timbre and depth of musical image are very good allowing one to sense the human hand and body at work.behind the instrument. Strings are rich and possess depth. Lesser supplies can emphasise the upper registers of violins for example, which can fatigue but also prevents the richer undertones from being heard and again prevents us from experiencing that human element to the playing. Percussive dynamics are excellent but don’t overwhelm the more subtle harmonics behind the sound. Bass lines are well delineated and the supply creates a satisfying depth to the soundstage and illuminates very nicely the subtle echoes running around the performance space at the end of each movement.
I like this supply a lot. I don’t have shares in the company so I’m just writing enthusiastically because it is always great to enjoy the company of an old friend in great form—my old tuner that is. A power supply can make all the difference to good listening; it is not just my imagination.
Old 11th October 2011, 06:00 PM   #515
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Any ampīs job is to modulate the PSU output with the incoming signal from the source.
It is natural for a good PSU to produce improvements in the amplifying chain.
You are not imagining things
RC
Old 11th October 2011, 10:02 PM   #516
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Back, thanks for the detailed impressions. A nice write up.
Old 12th October 2011, 12:31 PM   #517
My pleasure.
I have increased the size of the heatsink from 10degC/W to 3.6C/W and I can now hold my finger on the metal near the mosfet without discomfort. On the downside I can't get the lid on the box now. It might be possible to get away with 5degC/W.
Old 12th October 2011, 01:03 PM   #518
I did a pair of 800mA, 5V shunts for a Member. I used both 7C/W & 5C/W in them to ensure survival in worst case conditions.
400mA, 12V output will require similar heatsinks.
regards Andrew T.
Old 12th October 2011, 01:07 PM   #519
merlin el mago's Avatar
Welcome to Salas OLYMPO's regs. world.
This afternoon I finally plugged in the Salas BiB shunt regulator in to power up my old Quad FM4 tuner. The regulator is powered by an external toroid supply rated at 16VAC 1amp for each of its secondaries, only one of which is being used here. I listened first to a solo piano piece and what was immediately gratifying was an absence of glare from the piano notes. It is too easy to find piano notes sounding like wood blocks being knocked together and the resulting brittle glare is difficult to relax into. It also creates a two dimensional image but there was no sign of any of this with this setup; the absence of background noise allowed the dying harmonics inside the piano to be heard and the instrument was presented as a whole. With previous power supplies the piano often sounded an instrument of two halves, one connected with the right hand and another involved with the lower end of the keyboard. I think it is the ability to reveal the low level detail that allows the instrument to be seen as a whole. This ability to create a satisfying musical whole was apparent from BBCís next offering.
Schubertís unfinished was to follow played by the Scottish Symphony Orchestra.
Again the absence of background noise allowed individual instruments not only to be enjoyed in their own right with full and realistic dynamics but also to gel homogeneously with the rest of the orchestra. I have often listened to instruments appearing from the orchestra as though escaping from a dark background which is not unpleasant. But with the Salas in place the instruments can be heard against a background of other more subtle musical images such as quiet strings and woodwind. And these instruments donít disappear at low sound levels so the musical image is held together as a unit. I havenít enjoyed so much before the strings of the double basses and cellos holding their own as the rest of the orchestra joined. In the past they became lost in the overall sound but this power supply kept everything in focus. Timbre and depth of musical image are very good allowing one to sense the human hand and body at work.behind the instrument. Strings are rich and possess depth. Lesser supplies can emphasise the upper registers of violins for example, which can fatigue but also prevents the richer undertones from being heard and again prevents us from experiencing that human element to the playing. Percussive dynamics are excellent but donít overwhelm the more subtle harmonics behind the sound. Bass lines are well delineated and the supply creates a satisfying depth to the soundstage and illuminates very nicely the subtle echoes running around the performance space at the end of each movement.
I like this supply a lot. I donít have shares in the company so Iím just writing enthusiastically because it is always great to enjoy the company of an old friend in great formómy old tuner that is. A power supply can make all the difference to good listening; it is not just my imagination.
Old 12th October 2011, 01:18 PM   #520
I plan to do two regulators : 3.3v and 5v and i have 2x12v transfo .
Is it too high ?
Serge
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1627 14th January 2017 04:43 PM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 10:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 10:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 06:34 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 09:23 PM
Copyright ©1999-2017 diyAudio
