SSLV1.1 builds & fairy tales
Old 19th July 2011, 09:09 AM   #41
acidbrain is offline acidbrain  Netherlands
acidbrain's Avatar
It seems like there is a minor error in the manual at section 7.
C 203 is listed on the Vref parts and at the Zobel parts.
Am I right about this ? Everthing else looks splendid
Erik.
Old 19th July 2011, 05:43 PM   #42
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Yes, it should read C301.
Old 21st July 2011, 06:43 AM   #43
samoloko is offline samoloko  Bulgaria
there Is an error at BIBguide - Appendixes - 6 sinking - 2 sentence Q101 and Q106 are replaced
Old 21st July 2011, 12:26 PM   #44
Salas's Avatar
That one I spotted & corrected since I put the guide on hotfile.
Old 25th July 2011, 08:35 PM   #45
barrows is offline barrows
Default V 1.1 build problem.
Just fired up a mosfet BiB +/- boards, and I am not able to adjust voltage on either board. One is at ~ -13 V, and the other ~ +20 volts. Checked the trim pots (5K) and they are fine. Using 2 red LEDs, and 1K8 R203/103 with the zener position jumpered. Test load is 75R 5W, with sense wires hooked up.
BOM says Q104 is BC550 and Q204 is BC560, but the schematic appears to be confusing me? Clearly I have made the same mistake on both boards. Ideas?
Old 25th July 2011, 09:11 PM   #46
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Could you post a pic?
Old 25th July 2011, 09:19 PM   #47
Default Sorry...
Merlin, I am on dial up here, with an iffy connection to boot... No way am I going to try and post any picks from here. Looks cool though!
I ahve double checked thta the trim pots are not backwards, they are definitely correct. Everything seems like it should be fine, just weird that there is no voltage adjust???
Old 25th July 2011, 09:20 PM   #48
Salas's Avatar
Very small dummy loads. Use in the hundreds of Ohm.
Old 25th July 2011, 09:31 PM   #49
Default So...
Use R003? Is it OK to run briefly (with good sinking) at no load for voltage adjust, with sense wires hooked up of course?
Old 25th July 2011, 09:35 PM   #50
Salas's Avatar
What R1 you got there?
SSLV1.1 builds & fairy talesHide this!Advertise here!
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1661 31st January 2018 12:53 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 05:34 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
