SSLV1.1 builds & fairy tales - Page 47 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 6th October 2011, 05:26 PM   #461
The remote sensing twisted pairs. Which pairs are twisted? Is it +F with 0 and +S with 0?
I know it might not seem like it but I really am reading Salas construction guide--steep learning curve. Your patience is appreciated.
Chris
Old 6th October 2011, 05:27 PM   #462
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Did you read the guide?
P.S. OK I see you are reading it. F twisted together, S twisted together. If for just 30mA load, use 8R2 R101, 3 green leds.
Old 6th October 2011, 05:31 PM   #463
merlin el mago's Avatar
Originally Posted by Backbones View Post
Many thanks.
I see that Schottky diodes are not recommended. Is it the price or another reason?
Chris
Isn't the price, is the kind of diode.
Felipe
Old 6th October 2011, 05:39 PM   #464
Thanks Salas. R101 is 2W then (reading appendix 7).
Chris
Old 6th October 2011, 05:41 PM   #465
Salas's Avatar
Yes in your case it will be plenty enough. Use one led, 1k resistor, 3k trimmer in the voltage section, all unused positions jumper.
Old 6th October 2011, 05:50 PM   #466
Many thanks. I feel real progress has been made today. I am currently using an SPower regulator in this circuit and it will be interesting to compare.
Chris
Old 7th October 2011, 10:28 AM   #467
The dummy load resistor value to be used for testing. Is there a preferred value resistance for this assuming 12V output and a current draw of 0.03A? Do I calculate it from Ohm's law? I can see 5W power rating should be enough.
Chris
Old 7th October 2011, 10:39 AM   #468
Salas's Avatar
A 390R would simulate your 30mA load draw at 12V. But anything form 330R to 470R would serve the purpose. Your consumption and voltage range is low, so even a 2W dummy would do. The idea is to test a reg for target use, set it, without chance of jeopardizing a real circuit as load while tweaking.
Old 7th October 2011, 10:44 AM   #469
Many thanks.
Has anyone been using the reg for BA-2 front end do we know?
Chris
Old 7th October 2011, 10:54 AM   #470
Salas's Avatar
Not yet.
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1634 31st January 2017 02:57 PM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 05:34 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
Copyright 1999-2017 diyAudio
