YesAs the attached pic?
Its not silicone wire for sure, its spec states PVCTrusted the seller as tester silicon wire up to 1000V
Thanks Buddy. So if I use 4 green 2,1 Vf leds (=8,4 V) and VGS over the fet is say 4,7 V over 250ish mA that leaves 3,7 for R101. That means I could start with a 15 ohm and some hooked up variable resistor in parallell to work my way down/up to 250 mA. Does that make sense?
Or would it be preferable to go with 3 leds and lesser voltage to drop over R101 and choose a smaller value?
- Power Supplies
- SSLV1.1 builds & fairy tales
