SSLV1.1 builds & fairy tales
Old 5th February 2018, 07:59 AM   #4131
vitalica is offline vitalica  Europe
Resistor are Caddock 4R / 30W.
The problem has been solved, I forgot to keep in mind your advice to mount two 100UF capacitors on the preamp power jacks.
Now everything is stable and works perfectly.
Thank you so much for your support, Salas.
Best regards.
Old 5th February 2018, 08:16 AM   #4132
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Alright
Old 6th February 2018, 01:58 PM   #4133
AnthonyA is offline AnthonyA
Originally Posted by Salas View Post
Also remember that the Fairchild fast type Mosfet you expect is for CCS use (the one near the setting resistor). For the output keep the 9530.
OK followed exactly. The chips arrived fqp3p20. Tried whichever look more real. 2 ohm down to 0.5 ohm to get around 1A
Fantastic.. Went up another level of dynamism. Detail. Energy 3d.
Thank you Salas. Great help there.
Old 6th February 2018, 02:13 PM   #4134
Salas's Avatar
Old 7th February 2018, 11:50 PM   #4135
wcwc is offline wcwc  United States
For a DAC application, looking at +/- 12V DC output to the DAC, about 450mA CCA. Would a 2x 18VAC transformer work for this? I haven't bought the transformer yet, but I am getting ready to place the order for it.
Old 8th February 2018, 06:33 AM   #4136
Salas's Avatar
Will work fine but at a rather high 12V DC difference between rectified DC and output DC. That potential appears across the CCS MOSFETS and creates 12V*0.45A=5.4W dissipation in each one. Why not order a 15V-0-15V AC transformer and create 30% less heat on them at about 3.5W. The potential across those Q101 & Q202 TO-220s will be a good enough 7.75V for the CCS section to keep functioning within its healthy voltage spec range.
Those numbers are predicted when the mains and the transformer nominal voltages are taken literally. Mains are usually reported as 5V to 10V higher than nominal by DIYA members in North America, EU, and Australia. At least that's my general impression.
Old 21st February 2018, 08:35 PM   #4137
chromenuts is offline chromenuts  United States
Hi Salas
Iíve built your DCB1 Hypnotize version into a preamp with success...although I have to revisit the grounding and signal wiring as I got too creative I think. It does work well as I have it setup.
I have also managed to put together a gainclone based on Peter Daniels kit, one of the simple Boozehound phono MM kits, a miniDSP from boards and just finished a lengthy resto-mod of my turntable which included building a new motor control system designed and supported by Bill from Phoenix Engineering here on the forums. I hope this means Iím not a complete idiot, but I do struggle with the projects sometimes.
I have everything I would need to build your Simplistic RIAA project, but wanted to put it on the back burner for a little while.
My hope was to finish building a bass solution for my DIY Oris horns next while I continued to finally enjoy analog playback again after 9 months of having my turntable in pieces.
Unfortunately, I canít find a power supply that doesnít seem to create humming or noise with the Boozehound Phono Amp. It will run on 12-24VDC supposedly.
Iíve tried several laptop and wall wart supplies and they all cause it to hum or buzz. I resorted to ordering some rechargeable 24V robotics battery packs, but should have ordered 18V I think because they appear to be over driving the circuit causing it to create noise. I think this is because they are taking on a charge that exceeds the specified output. I measured them at 25-26.5 VDC at the output connectors.
So I ordered some SSLV kits and have them on hand. I read over the PDF manual...but it wasnít entirely clear to me how to proceed as it has been with other projects Iíve built. Perhaps Iím just distracted by all the variables being discussed.
I was looking for a post or build thread that would help me fill in the blanks, so to speak, on building an SSLV with an output of 18VDC for the the Boozehound phono amp.
The manual info tells me:
c. 10V-25V Mosfet reg. 2 1.9V LED, 1.8 kOhm R303. 5K trimmer. Other parts jumper.
Other posts Iíve read over so far seem to point toward using a 15V transformer. I have a 50VA 15-0-15 SumR transformer on hand.
What else do I need to understand or have on hand before I dive into this project?
Thanks for any guidance you can offer.
Kevin
Old 21st February 2018, 08:51 PM   #4138
Salas's Avatar
Kevin hi
For a phono like that with zero PSRR use 470uF 25-35V C101 in the regulator to filter its reference voltage components noise well.
For 18V DC output you need at least 18VAC input with the SSLV for proper CCS work and safety from mains tolerances. You could think creatively though by putting voltage dropping resistors after a 30 VAC configured SumR. Its easy to predict because there will be constant current draw in the regulator that you will decide. See with the Duncan PSUD2 free simulator. That way you can go to 24V output too. Just allow 10V drop or more from rectified input DC to regulated output DC.
Old 21st February 2018, 10:01 PM   #4139
PSRR is Power Supply...??. Sorry I am trying to learn here. Most of what I have built has been “connect the dots” so to speak.
I also have some Antek 12-0-12 trannies that I bought for another turntable controller project that will not happen any time soon. There are probably more than I will use, and I can always order a replacement. I think they are 100VA...could be 200VA. Overkill I think, but would they make things easier for me?
Your talking about AC input of at least 18VAC...and then mention DC rectified input to regulated DC output... this is confusing me. Doesn’t the SSLV have a recitifier section on board that accepts VAC directly from my transformer?...or am I not using that section for some reason because I only need a single positive rail and ground to power the phono amp?
Old 21st February 2018, 10:48 PM   #4140
Salas's Avatar
PSRR = Power Supply Rejection Ratio. In other words not all circuits have the same susceptibility to rail ripple and its other possible noises.
Yep, overkill. But 12-0-12 can make 24 with its secondaries in series and its a good figure for your purposes.
The board provides AC input that gets rectified and smoothed by local diodes and a filter capacitor. So it turns to DC that includes ripple thus named raw DC. You can measure that DC level across the big filter capacitor. Nonetheless the pure regulator section is DC to DC as any. So raw DC is its input DC. Term like when talking about an LM317 or 78XX reg chip etc.
SSLV1.1 builds & fairy talesHide this!Advertise here!
Legis' Horny Tales Legis Multi-Way 176 11th September 2017 12:21 PM
Any successful/unsuccessful tales of loading a large Coax in a front horn? POOH Multi-Way 35 22nd November 2015 08:58 PM
Fs: Salas SSLV1.1 BIB janos_904 Swap Meet 13 27th May 2015 08:36 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
