SSLV1.1 builds & fairy tales
Old 23rd August 2011, 03:00 PM   #301
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Too heavy a dummy load. Should be drawing half your CCS to 3/4 is correct. Use a 15R 2W-5W dummy to emulate ~220mA draw, set for 350ma to 450mA CCS. Check voltage drop across R301 to estimate what current you have available to use.
Old 23rd August 2011, 04:20 PM   #302
merlin el mago is offline merlin el mago
merlin el mago's Avatar
15R 5W dummy load
Vout +1.52V still can't adjust Vout with the trimmer
Voltage across R301 12R (+1.22V)
Old 23rd August 2011, 04:24 PM   #303
Salas's Avatar
This way you got 100mA only. Go down 2.7R R301, keep the dummy @ 15R.
Old 23rd August 2011, 04:50 PM   #304
R301 2R7 (voltage across 0.81V = 300mA)
Vout 3.3V
Now YES: trimmer adjust Vout & all LEDs lit strong
Time to compare vs Trident TP stuff
Old 23rd August 2011, 05:05 PM   #305
Salas's Avatar
Is the real circuit's constant consumption about 200mA?
Old 23rd August 2011, 05:08 PM   #306
Trident max Iout 100mA
Old 23rd August 2011, 05:13 PM   #307
Salas's Avatar
You will have to know what the circuit draws without Tridents since you are about to check without them. I have read that a Buff 2 draws 410mA with Tridents on it. Anyway, keep in mind to have whatever it needs in the end +100mA in CCS reserve. If it takes 200mA for instance, you are OK with 300mA.
Old 23rd August 2011, 05:23 PM   #308
I lowered R301 till 2R2 so now I have 330mA, I will do the comparison vs the Trident clock regulator
Old 23rd August 2011, 05:27 PM   #309
Salas's Avatar
I am not Russ to surely tell you what consumes how much in those modules, but I trust you will make it out in practice. Its shown that your reg works when the currents are at correct proportions, that's enough to start. Good luck.
Old 23rd August 2011, 06:42 PM   #310
Soul COME BACK
Better & more bass, more transients, more fast, better mids, glorious highs.
No Tridents, No Lifepo batteries, winner Salas BiB regulator
N.B. When your regs are more near the signal is born sounds better
SSLV1.1 builds & fairy talesHide this!Advertise here!
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1661 31st January 2018 01:53 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 10:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 10:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 06:34 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 09:23 PM
