SSLV1.1 builds & fairy tales
Old 8th May 2014, 11:38 PM   #2771
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by alexkosha View Post
Hi Salas,
Thanks a lot. I like these composers a lot, but I did not have nice records to fully enjoy my TT. Now, I'll have the chance finally to hear it in best sound quality. Thank you. Would you please also recommend anything in instrumental (and vocal) Jazz sector?
Thank you.
BILLIE HOLIDAY SONGS FOR DISTINGUE LOVERS (180G 45RPM 2LP) at Music Direct
Old 9th May 2014, 01:45 AM   #2772
alexkosha is offline alexkosha  United States
alexkosha's Avatar
Yep, that is what I like too.
Thank you. I already made purchases, beside "Hungarian Rhapsody No.2".
http://tinyurl.com/qfnlnsq
It is an eBay sale and I'm not sure about authenticity....
Can't wait to turn on my TT with these LPs.
Thank you very much.
BTW, Tchaikovsky and Rachmaninoff, both are my favours from Russian sector. Can't understand Alfred Schnittke and Igor Stravinsky....
To much disharmony for me...
Old 12th May 2014, 08:23 AM   #2773
alexkosha's Avatar
Hi Salas,
One more question just to be sure....
I set my 2 BIBs boards for 300mA with 4 green LEDs and 12R Caddock for R301s.
My headphone amp uses about 150mA, or so.
All Q306 and Q301 are at room temperature or close, and R301 is warm ( about 40 deg C).
Is it normal?
I remember, in my BHL, Q306 and Q301 are runs really warm....
R301 is warm too.
Here they kind of cold.
Thank you.
Old 12th May 2014, 12:19 PM   #2774
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
Leopold Stokowski Liszt Enesco Rhapsodies 200 Gram 33rpm SEALED Vinyl LP | eBay
One of my favorite LPs... I got this twice
If analogue productions re-issues it with the rest I will buy it at least once more
Unfortunately the SACD is not nearly as awesome...
+1 for Stravinsky... he has some good moments, but not really my cup of tea...
Too many projects... so little time...
Old 12th May 2014, 04:08 PM   #2775
Salas's Avatar
Hi Salas,
Is it normal?
R301 is warm too.
Thank you.
Means you can utilize more spare current in this new one. Your Vin-Vout, sinks size, and high enough headphone amp consumption resulting in lukewarm operation at now CCS level say that you may try 400mA+ and stop where the temperature becomes uncomfortable. 50C on sinks should be safe. Usually you can hear a subjective upgrade by doing that. Objectively the regulator's output impedance falls by few milliOhm further. Don't forget to verify the now and then running current by measuring the voltage drop across the setting resistor and then divide it by its value in Ohm.
Old 13th May 2014, 03:07 AM   #2776
alexkosha's Avatar
Based on V-drop across R301 and 12 Ohm value, my current in-use is about 250mA. Please see attached picture.
So, if I'll go for 8.2 Ohm my set will go to 416mA (calculation based on your "SSLV1.1 Calculator V1a.xls").
Old 13th May 2014, 03:22 AM   #2777
Salas's Avatar
Yep, try that. Should be beneficial.
Old 13th May 2014, 03:23 AM   #2778
Salas's Avatar
P.S. Make sure the KM can stand it though. Maybe settle for 300mA?
Old 13th May 2014, 03:26 AM   #2779
alexkosha's Avatar
Good point... I'll ask Kean about current limit on KM.
Thank you.
Old 14th May 2014, 04:06 AM   #2780
alexkosha's Avatar
Thank you.
Kean got back with the answer.
So, no problem to run original KM (design with LED) up to needed 400mA, but need to add some input capacitance for these who calculated ripple based on lower current. In my case, we used extra capacitance at the beginning and I'm OK to run it as is. Going to purchase Caddock MP930 8R or 8.2R for R301 today. Update you as soon as possible.
SSLV1.1 builds & fairy talesHide this!Advertise here!
Legis' Horny Tales Legis Multi-Way 176 11th September 2017 12:21 PM
Any successful/unsuccessful tales of loading a large Coax in a front horn? POOH Multi-Way 35 22nd November 2015 08:58 PM
Fs: Salas SSLV1.1 BIB janos_904 Swap Meet 13 27th May 2015 08:36 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
