SSLV1.1 builds & fairy tales
Old 6th April 2014, 06:48 AM   #2741
2channel is offline 2channel  New Zealand
Oh, and connect according to capacitor polarity as shown, (Ignore my layout of the Salas). If the caps are wired with the wrong polarity then BOOM!
Old 6th April 2014, 08:15 AM   #2742
bkdog is offline bkdog
Originally Posted by 2channel View Post
The picture below shows a standard split rail rectifier using a single bridge. You can use individual diodes.
Is this what you are trying to achieve?
Jeremy
Jeremy, I think that pic is wrong, it's wrong on the site it came from, the bridge is connected the wrong way. I think it should be like it is shown here: Bridge Rectifier, Power supplies
Old 6th April 2014, 02:21 PM   #2743
necplusultra is offline necplusultra  Canada
thanks all,
I ended up using 2channel's corrected schematic (the schematic shown is erroneous).
I did not want to use an external rectifier so I decided to use the onboard diodes and jumpers to implement the schematic. I'll try to post pics asap.
regards
Old 6th April 2014, 05:25 PM   #2744
Default center tapped balanced supply example connection
Here's my connection for a balanced supply with a center tapped transformer
Old 9th April 2014, 03:35 PM   #2745
Peterma is offline Peterma  Australia
Hi i was wondering if someone could help me with my salas shunt modules from the tda1541 red baron dac forum, the positive regulation works but the negative modules arent working at all voltage in is good and has negative volts going in but no reguation, leds arent lighting up and cant adjust negative voltage, thanks if anyone could give some advise
Old 9th April 2014, 03:40 PM   #2746
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Are the 4 LEDs in backwards possibly?. It's not like I don't do that all the time
GB 2017 #2 CLOSED, Boards on Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards Available, PM
Old 10th April 2014, 11:53 PM   #2747
Thanks for your help I found the problem just earth connection.
Old 18th April 2014, 06:03 PM   #2748
alexkosha is offline alexkosha  United States
alexkosha's Avatar
Hi Salas,
Please advice what Ele-cap would be a good choice for C102/C202/C302 with 50V. In my case, Nichicon KZ and Elna RFS are both 16 mm dia. It is too big for me. I need something 10 - 12.5 mm MAX.
How bout Panasonic FC or FR? They are both 10 mm in dia.
I'm not sure about quality vs. Elna or Nichicon and low impedance caps usage in that position...
Thank you.
Old 18th April 2014, 07:19 PM   #2749
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
C102/C202/C302 are film cap positions. C101/C201/C301 are ecap positions. Nichicon Muse KZ 100uF 50V is 12.5mm for instance. Which is enough of filtering if not for a particularly noise sensitive application. 220uF 35V Nichicon Muse ES BP is 12.5mm too if Vout<35V. Then there are the FC & FR of course. Which are very long life and good quality in general.
Old 18th April 2014, 09:19 PM   #2750
alexkosha's Avatar
SSLV1.1 builds &amp; fairy tales
Got you. I need 50V since I use about 40-45V out.
So, I'll use Pan FR 270uF 50v. I have them in my stock.
Thank you.
SSLV1.1 builds &amp; fairy talesHide this!Advertise here!
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1659 15th January 2018 10:23 PM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 10:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 10:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 06:34 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 09:23 PM
