SSLV1.1 builds & fairy tales
Old 21st November 2013, 03:48 AM   #2541
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
It was half a lucky shot because I don't know what else can be at play when something is not examined on my bench also. But you were doing the correct experiments and we found a way.
Old 21st November 2013, 05:50 AM   #2542
stajo is offline stajo  Sweden
Originally Posted by Salas View Post
Stajo will advise you on that, who has a stash of chokes to check out. Me I said use a cmult cascade at the output.
Sorry I was too late, but hey congrats, you solved it.
To make an after analyze, I would do a voltage check before and after the 317. It should kill your ripple better. Do you really have sufficient vdrop concerning both amps and temp in the datasheet? To that you must add at least the ripple level (PP/2 I think, not sure) before the 317.
Old 21st November 2013, 07:52 AM   #2543
nvduybom is offline nvduybom  Viet Nam
nvduybom's Avatar
Hello,
I use BJT kit and set 600mA CCS (440mA load) for Buffalo IIISE . Can I use all red LEDS (D102,D103,D104,D105,D106) ? .
Thank you.
Van Duy
http://www.vnav.vn/forum
Old 21st November 2013, 08:03 AM   #2544
Salas's Avatar
If they give 1.9V at 2-3mA yes. Test one with suitable resistor and voltage to verify forward voltage drop at such current levels.
Old 21st November 2013, 02:27 PM   #2545
alexkosha is online now alexkosha  United States
alexkosha's Avatar
My voltage before 317 was 19.3v from Raw DC when amp connected. After 317, 13.8v stable. No heat on sink (about 30 deg C constantly).
Old 21st November 2013, 02:49 PM   #2546
nvduybom's Avatar
Thank Salas for your quick reply ,
With +- 15VDC for Legato, Can I replace Q104, Q204 (BC550, BC560) by BC548B, BC558B ?.
Old 21st November 2013, 03:13 PM   #2547
That should be fully satisfactory for it to bring home the bacon. A wild guess that you have between 0,7 and 1,0 vrms ripple before it and it should have no problem with bringing down that with 60-80 dB.
Harsh spikes from rectification tho can be another story. But now you have a working PSU to enjoy.
PS. My earlyer comments about voltage before and after choke assumed that the choke was first thing after rectification. On later pix I saw that was not the fact, so that can be ignored.
Old 21st November 2013, 05:51 PM   #2548
alexkosha's Avatar
I'm fully satisfied (thanks to Salas) , but any way if you will use choke setup there (alternative way to emiter capmult) , then what values of choke would you suggest for such circuit?
Old 21st November 2013, 08:02 PM   #2549
Salas's Avatar
Better not because they have worse noise figure spec.
Old 21st November 2013, 10:58 PM   #2550
Well chokes in series is like everything else, ohms law. If your current is I=U/R=12/500 (bleeder) you have 24 mA to deal with and you just find a choke that takes the limit. Add the current of your devise and maybe 50 mA is a good one in your case. If you, like I first thought, use the choke as first element (L-C) in a filter chain, it has to deal with much larger ripple, and my approach is to at least double the current spec.
What comes up is: When you use a cap, large enough, as first devise, the voltage after rectification will be AC x sqr2 minus the voltage drop over each rectifier diode. In a greatz bridge its two diodes so its (AC x 1,41) minus (vdrop x 2. In your case (14 x 1,41) - (0,7 x 2) = 18,3 volt.
If you, on the other hand, puts the choke as first device, you will only get AC x 0,9 volts minus vdrop on diodes. You might win that some spikes from the rectifications that not gets enhanced by the first cap and further into the circuit.
It takes more voltage to start with tho. In tube circuits, where you might want 3-500 volts, it might be encumbering to make an L-C. In low voltage circuits tho, if you find good availiable chokes, its my first choce.
My fav circuits in tube circuits is usually a middle way: small cap-small inductor etc. You can set the voltage with the size of the first cap, and your noice pollution will be minimal.
SSLV1.1 builds & fairy talesHide this!Advertise here!
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1644 13th October 2017 07:11 PM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 05:34 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
Copyright ©1999-2017 diyAudio
