Go Back   Home > Forums > Amplifiers > Power Supplies
Old 20th November 2013, 07:08 AM   #2531
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by dimkasta View Post
Nick kalimera
I wanted to ask, is there an optimal temperature that the fets should work in?
I do not expect you to give me a specific Celsius value. But I am currently using a big heatsink for one of my BiBs and it is running pretty much cold. Should I allow the fets to heat up a bit ?
Thanks again
In electronics the cooler the better if its not a matter of needing extra power. In case of a bib, extra power can go towards lower self output impedance, so why not take some advantage of the spare cooling and rev it up a bit.
Old 20th November 2013, 07:10 AM   #2532
alexkosha's Avatar
Originally Posted by Salas View Post
One cell you already got, just add the end part. At 120Hz it does even more. It basically flats out 10-20dB even better towards the highs.
Like this?
Old 20th November 2013, 07:17 AM   #2533
Salas's Avatar
Yes, easy. You will need 13.2V output from the 317 for the two vbe losses now. I would stick the second cell right on the BHL receive points to avoid that EMI we suspect finding cables to creep in again.
Old 20th November 2013, 07:18 AM   #2534
Dimitris
dimkasta's Avatar
In electronics the cooler the better if its not a matter of needing extra power. In case of a bib, extra power can go towards lower self output impedance, so why not take some advantage of the spare collong and rev it up a bit.
Yeah it was in the back of my head to try something like that... I just need to get a bigger trafo. Big smile
We don t need no water let the freaking thing burn
Second harmonic and semi-sweet wine for everyone...
Old 20th November 2013, 07:22 AM   #2535
alexkosha's Avatar
Got it. I'll try and report back.
Old 20th November 2013, 07:23 AM   #2536
Salas's Avatar
TMS 1978 The Trammps - Disco Inferno (Burn Baby Burn) - YouTube
Old 20th November 2013, 07:31 AM   #2537
Salas's Avatar
OK
Old 21st November 2013, 03:20 AM   #2538
alexkosha's Avatar
OK
It works. Very quite now. Please see final setup.
Thank you Salas.
Old 21st November 2013, 03:26 AM   #2539
Salas's Avatar
He, he, told ya, more elegant and saved you the bulky costly iron quest.
Old 21st November 2013, 03:37 AM   #2540
alexkosha's Avatar
You are right as alwayse! Again, that you a lot.
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1427 21st April 2014 01:48 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 05:34 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
