Go Back   Home > Forums > Amplifiers > Power Supplies
Old 9th August 2013, 02:20 PM   #2361
roger57 is offline roger57  Canada
roger57's Avatar
Originally Posted by Marra View Post
I'm sure I read it somewhere back in the thread but can't seem to find the information that I am after. I have two R cores one with 2x15v secondaries and the other of better quality with 15-0-15v is it possible to use the latter to power a bib? Tia.
Seems OK. That'll give you 15V rms across the outside windings with the center tap at ground. Use a 2 diode configuration. Voltage might be a bit high, but you can also use a dropping resistor to bleed a bit of that voltage down if needed.
Old 10th August 2013, 09:30 AM   #2362
15Vac is the usual supply for a regulated 15Vdc.
But the CCS then Shunt drops more voltage than a normal series regulator.
You may find that on low mains voltage the Shunt regulator drops out.
For +-15Vdc I'd suggest you use 18-0-18Vac
regards Andrew T.
Old 10th August 2013, 10:11 AM   #2363
Marra is online now Marra  United Kingdom
Thanks Andrew;I do have an Rcore with 2x18v secondaries so I guess thats the one to use.
Old 10th August 2013, 11:27 AM   #2364
That should give plenty Vdrop across the CCS stage.
regards Andrew T.
Old 8th October 2013, 03:53 AM   #2365
alexkosha's Avatar
[QUOTE=Salas]
Originally Posted by alexkosha
Hi Salas,
I learned BIB manual and come up with the final setup list.
I need your advice about general set (if I understood what and how correctly) and precision for 301.
1. a. Vin from Raw DC = 39.9V
b. Vout (which I need for BHL) = 24V
c. Constant current (R301) = 200mA (per your advice for current limit)
d. Load consumption = 50mA (measured about 30mA with Fluke DVM on idle)
e. 3 Yellow or Green LEDs = all for 2.1V (D102A Vf = 0)
f. Q103 Idss = 4mA (not measured, and left as is) – how important to measure it in such precision? Also how important to set 302,303 and 305 in gain progressive order?
g. 2 Red LEDs = all for 1.9V
h. R103 = 1k8 1/4W (per EXL with 5k potentiometer) – Any particular brand/% spec/PPM?
i. Temp and safety factor is the same as in your initial table.
So, R301 is calculated to 8R9. I can’t find such value and since you mention “ballpark” values then what should I use: 8R2, 9R1 or 10R?
Kiwame 5W – is this one should be OK? Any other preferable brands and types?
You already advised about heatsink for 8W and I have it.
Last question: if I use Raw DC in separate box based on you Folded manual, then I do not need to use rectifier and (C305) 4700uF in input section of BIB. I need to bypass it. Right?
It will help me a lot.
Thank you.
Answer from Salas:
e. Green are easier to find in 2 to 2.2V than yellow
f. 10% will do. The other two can be randomly populated if not over 5mA.
g. One red led will be enough in your case. Jumper the 2nd led's pads.
h. Vishay or alike metal film no more than 100ppm
R301. Use 8R2 2W Vishay or alike up to 100ppm or Caddock MP925 or 930-8 without sink. Some claim the Caddock is the most synergistic.
Old 8th October 2013, 03:56 AM   #2366
alexkosha's Avatar
[QUOTE=Salas]
Hi Salas,
Thank you for that detailed answers. I'll flow your directions as soon as I'll receive BIB kit. tea-Bag committed to sent it over at the end of October.
How about my "last question": If I use Raw DC in separate box with umbilical cord based on your Folded manual, then I do not need to use rectifier and (C305) 4700uF on input section of BIB. I need to bypass it. Right?
One more: can use 9V battery to test JFETs?
They asked for current limited PSU in that guide, but why batter is not enough to use there?
Thank you.
Answer from Salas:
Right, bypass it. Go directly to the pins of the local 4.7mF cap's position. You could also use 470uF there for decoupling and termination of the incoming wires though.
You can use 9V batteries alright.
Old 9th October 2013, 05:48 PM   #2367
alexkosha's Avatar
Hi Salas,
I have a question related to BIB manual.
You mentioned that R105, R205 and R305 should be equipped with Trimmer Bourns 3296Y style. I see that all pads on PCBs are in-line and such design required 3296W and not Y. Please see attached SPEC and let me know which is required: W or Y.
Old 9th October 2013, 06:06 PM   #2368
I've just checked my bib pcb's and they are drilled and have solder pads so that you can use either.
Old 9th October 2013, 06:11 PM   #2369
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Yes, that photo is from the prototype. All the circulated boards had both options pads. ;-)
Old 9th October 2013, 09:06 PM   #2370
alexkosha's Avatar
I see. Thank you.
I did not get my BIB PCB yet, but I did see the picture in manual.
At that case I safe...
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1424 9th April 2014 02:33 PM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 05:34 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
