SSLV1.1 builds & fairy tales
Old 17th May 2013, 04:07 PM   #2241
bigpandahk is offline bigpandahk  Hong Kong
0.793V at 1 Ohm, 8.45AC input, output at 5.5V 600mA. Output drop when current higher than 600mA.
edit, max output current should be 800mA, not 600mA
Old 17th May 2013, 04:19 PM   #2242
I think the CCS is getting starved.
The shunt then compensates by reducing the shunt current to try to keep the output voltage up.
You must get adequate voltage drop across the CCS to get proper CCS operation.
regards Andrew T.
Old 17th May 2013, 04:54 PM   #2243
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The sinking must be good for the CCS MOSFET at those currents also. Maybe an IRF9530 in place of the IRF9610 if the situation is too hot for given sinking at 1-1.2A setting. Looks like starving and TC shifting now. Circa 0.75R looks more appropriate to use now either as a single R101 or by piggyback of a 3.3R on the 1R. Check for possible ducking of input voltage while at work also. You can measure the rectified DC there:
Old 17th May 2013, 05:03 PM   #2244
Thanks Andrew and Salas.
Sink is big enough and it is not even warm.
Old 17th May 2013, 05:10 PM   #2245
Salas's Avatar
But the CCS MOSFET conducts heat well to the sink? Is it too hot itself?
Old 18th May 2013, 12:13 AM   #2246
drawing 800mA for 10 minutes, the MOSFET temperature stable at 41 deg C.
Old 18th May 2013, 01:07 AM   #2247
Parallel a 3.3ohm to the 1 ohm but result is the the same. O/P drop when current exceed 800mA. Input voltage remain at 8.7Vdc till 900mA
Old 18th May 2013, 01:28 AM   #2248
Salas's Avatar
It was at 600mA to start dropping before though. 8.7VDCin-5.5VDCout=3.2VDCdrop over the CCS. How many CCS Leds you use and what is the voltage from lowest one to ground?
And how much is going to be your max real load demand?
Old 18th May 2013, 01:43 AM   #2249
Salas's Avatar
See this graph attached. Its the 9610's ID/VSD curves. If you want it pass ~1A it will need ~4.7VSD to maintain it. You got to add the R101 setting resistor's drop to that up to VinDC. If your Vin-Vout does not give you that margin it will start dropping from a lower draw. That is what Andrew wrote about too.
Old 18th May 2013, 09:18 AM   #2250
RollE2k is offline RollE2k  Sweden
Here is how my 2x SSLV-positive smaller pcb's turned out. Will use them two pcb's to feed the Sen I/V :-)
SSLV1.1 builds & fairy talesHide this!Advertise here!
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1659 15th January 2018 10:23 PM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 10:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 10:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 06:34 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 09:23 PM
